Question about Kitchen Ranges
I have a belling cooker switch that has had 3 contacts welded together, i have ordered a new switch but where can i find a wiring diagram to check the conecction for the new switch
Have a belling 862 and the grill switch will not regulate can anyone tell me the type of simmerstat that is required?
Posted on Feb 11, 2009
Belling oven xou60mf not switiching on
Sometimes I had it where the lamp holder in the oven has a short and then welds the contact on the function switch. If you replace the complete lamp and holder and function switch for the oven. 3 time last year on bellings this happened. To try disconnect the two wire on the lamp holder then if it doesn't trip you no that's it make sure you turn the oven off and don't touch the wires together when u turn back on.
Jan 14, 2014 | Ovens
2006 yamaha grizzly starter wont stop cranking
Possible solutions;
1. starter contacts sticking-take the switch apart and clean the contacts or repalce the swtich.
2. wire to starter button shorting/grounding-look for broken/shorting wire from the starter switch.
3. starter solenoid contacts welded together-replace the solenoid
Aug 21, 2012 | Motorcycles
Carrier Weathermaker 8000 error code 32
Hi, if its blinking 3 fast and 2 slow and saying the error is the pressure switch, kill the power. Pull the hose loose from the inducer motor to the switch and blow back and forth. You can hear the single pole contact click open and close. Put it back together and try it again. If it continues, check for any leaks in the air lines first, and if not, replace the switch. You would be better off to order one over the Internet.For a temp. fix only, if the switch contacts are welded shut or open, you can bypass this safety by taking a piece of electrical wire with clips on each end, and jump across the 2 wires. Some have 3 just find the 2 that makes it work. Good luck,
Shastalaker7
Nov 09, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a GE Profile Model# PDW7700G00CC that trips the circuit breaker when I hit the start button to begin a wash cycle. Green lights are on when I re-energize the unit but problem repeats when I hit...
It sounds like a dead short tripping the CB or a ground fault (short to ground) if the CB is GFCI type.
At start it would energize water valve solenoids, water level sensor (float switch), a timer. These components and circuit should contain the source of the problem.
Find the machine's wiring diagram in the control panel or glued on a panel. Open the control panel and do a visual inspection.
Sometimes a dead short will weld contacts together, check contacts and relays. Isolate parts of the circuit energized tripping the power
Jul 03, 2017 | Dishwashers
Hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Apr 19, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
Suddenly the rice cooker stops working
If you have had it for a while.. the keep warm function may not work if the one of the 2 wires for the lid temp sensor plate have broken in the hinge area. This is a very common failure in well used rice cookers.
Apr 13, 2010 | Oster 4724 Rice Cooker
95 Toyota Camry power window fuse keeps blowing
the window switch is stuck even if you work it with your finger and it doenst feel stuck the brass contactes are welded together on the in side of the switch try a new switch or take the one you have apart ... becarefull thu lots of springs and some sall parts inside
May 16, 2009 | 1995 Toyota Camry
User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Aug 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
369 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
