Question about Sony SLV-940HF VCR
Sony SLV940HF What causes a double vision picture when using my VCR? I recently bought this VCR from someone but have had this same problem in the past with other VCRs. Do you know what the problem could be? When playing a movie I get like a double vision picture. When showing a person you see one clearly and a faint picture of the same person just to the left of them.
Since you have had this problem with other VCR's, it is very likely to be a problem with the connecting cables. Defective cables, or too many cables (daisy-chaining more than a few devices) can cause ghosting, which is what you're experiencing. Try a new set of cables from the TV to the VCR, and also from the VCR to any cable, satellite or outside antenna.
Posted on Aug 03, 2007
SOURCE:
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I am seeing double vision on my television.
I do not know your TV's model number, if your TV is a 3D television, please turn the 3D function off in the system menu.
Jul 01, 2017 | Sony Televison & Video
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
I have a remote diamond vision vcr/dvd
if yours plays DVD's I will take it off your hands.
The one I bought from Walmart has never played one disc. Always says wrong disk. Factory set for region 1 and I live and bought it in region 2.
Jul 13, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Mar 01, 2008 | Sony KP-61S65 61" Rear Projection...
Double vision on my samsung HDTV 1080i
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
