Question about ViewSonic N3251w 32 in. LCD HDTV
No power to TV. Will not turn on.
TV was working great. I've owned it for about two years. Last week I went to turn it on and nothing. It was like it was not getting any power at all. I removed the TV and tried plugging it into a wall outlet (actually) several. Still nothing. The TV is run with a comcast Explorer 8300 HD cable box. When I plugged the TV into a wall outlet, it wasn't connected to anything. It just seemed like it the TV wasn't getting any power at all(?).
  • 1 more comment
  • hannanmd Jan 25, 2009
    exactly the same problem as William. after 2 years, no power.
  • flyatnight Jan 31, 2009
    Viewsonic LCD TV/ N2630w:  LED indicator light is "pulsating" red.  Cannot turn TV on.  No screen.  Tried everything.  If LED indicator is flikering it is getting power?  HELP.
  • jlt0729 Feb 10, 2009
    power indicator inop wont turn on at all
    Problem Solver:
  • 4 Answers
I had the same problem... I fixed it by replacing 4 bad capacitors on the Power Module PCB.
Thanks,
Jerry.nelson.nj@comcast.net
Posted on Feb 14, 2009
Replace the power supply about 60.00 dollars from viewsonic
Posted on Jan 16, 2009
TV will not power on
Inspect the lamp again. When you replace it, make sure you DO NOT TOUCH the glass. Make sure all doors and covers are securely in place before you turn it on.
As a rule, expensive lamps have a very short life.
May 01, 2017 | Panasonic PT-43LC14 Television
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
My 32 inch Audiovox flat screen will not turn on????? Was on and working fine 30 minutes prior.
hello, do you mean it's dead if so the fuse inside might have blown
regardsshaun
May 12, 2012 | Audiovox Televison & Video
Last summer we installed a Intex salt water filter it worked great for about 2 1/2 months. It stopped working, Checked the power supply nothing was coming thur it. Intex relpaced it under warranty. Started...
This could be a flow problem and you will need to check your pump baskets for junk and make sure your filter is clean. Also you can check your flow switch to be sure it is working.
Aug 13, 2011 | Intex Automatic Salt Water System for ...
I've owned this great little Black and Decker CST800 grass trimmer for 6 years and only use it in Montreal summers (5 months long). Just this past week, I brought it in to recharge it and left it for 5...
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
Jun 15, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
We own a Toshiba Regza 42" direct view LCD TV. We have owned this since last November (bought as a Christmas gift). This TV was working great until last night (7/7). Powered it on and for a split...
Unfortunately there might no be a fix for this type of failure unless the LCD is open and perform a few measurements in the circuitry. Since the TV is less then a year old, I would suggest to contact the vendor or manufacturer to have it repair under warranty, most electronics devices carry one year warranty.
Let me know if you require further assistance.
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
ViewSonic N3251w 32 in. LCD HDTV Logo
257 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
