Question about Logitech R-20 Computer Speakers
Deep Deep Sounds
I just recently purchased these speakers and the sound is unusally deep sounding, like if you were to hear something that usually has a high note it'll sound very very deep. Help will be appreciated thanks.
  • Alan Nguyen Jun 22, 2007
    I tested it without the sub woofer and there's still a deep sound, I tried different speakers and the problem is still occuring, I think it's a software problem.
    I tried listening again this time and the background music is normal, it's just the sound of the singer's voices... they just sound unusually deep.
    I'm sorry, I don't understand can you be more specific.
    I went into contol panel and checked the speaker setup in Sounds and Audio Devices Properties and it's currently set on desktop stereo speaker. I tested the speakers on different speakers setups and I'll still ahve the same deep voice problem :S.
    Problem Solver:
  • 8 Answers
Are you sure you are hearing sound from the two main speakers and not just the sub-woofer?
Posted on Jun 18, 2007
    Genius:
  • 2,985 Answers
Describe the control set up on the speakers and also the sound system on the computer
Hamilton Beach Triple Head 940 Milkshake Mixer stop working
Sounds crazy but check for power at the outlet. If that's good then possibly a bad cord,Power switch or interlock safety switch if it has one. Do you hear a humming sound when you try to use it? If so the motor is frozen up. Hope this helps.
May 24, 2014 | Pitco Frialator SG14 Deep Fryer
Infinity BU- 80 sub sounds over driven or blowen
from what im seeing in the picture, you have a house surround sound sub wolfer an there supposed to soumd deep an the crossover controls this there not ment for continues music an house an car speakers are different ohloms the lower the ohloms the deeper the bass
Jan 09, 2014 | Audio Players & Recorders
Distorted bass
Sounds (sorry) more like a PC/Laptop/player problem to me. Headsets like these don't usually just fail in this way.
Dec 28, 2013 | Genius HS G550 Lychas - Headset ear-cup -...
Fryer burner shuts off at 250 pilot light stays lite ?
Sounds like thermostat is bad? For confirmation on this, call our service tech, Ray at 888-542-5959 at Restaurant Equipment Outlet, Cincinnati, Ohio. We normally ship parts in 1-2 days if you need something... Thanks, Susan REO
Jun 12, 2011 | Imperial IFS40 Deep Fryer
Hello. I just purchased these speakers and there is a low static hum in them. Also, if I turn up the bass volume on the subwoofer I get a deep hum and no sound. Any assistance would be greatly...
Double check your wiring again, sounds like something is either not hooked up right or maybe you got faulty speakers. There shouldn't be any hissing or humming in any speakers. Get a flash light and make sure you have it in the right spot on your computer most sound cards have about 5 different jacks you could have simply put it in the wrong jack.
May 15, 2011 | Cyber Acoustics CA-3080 Computer Speakers
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
I have an Onkyo HT-R8230 receiver and I can not get any sound out of the center channel or the subwoofer. The sub will not even power on. It stays in the standby mode and there is no manual on/off button...
The manual is available at retrevo.com.
If you don't have the center and sub defined in the Onkyo they will never work. See page 20.
If that is all set and you still have problems...
To prove the center speaker works, connect it to one of the front channels.
To prove the sub works, connect it via RCA cable(s) to the Tape Out and play something containing deep bass. You should see it come out of standby and hear something, albeit only the deep bass.
Aug 03, 2010 | Onkyo HTR500 Receiver
Hello! I recently bought a 1982 650 honda nighthawk.It has like rattle sounds in the engine.What is this,or what can it be? Please tell me there is a fix!! Thank You Kindly Dave
hard to tell with out hearing it. but if it sounds deep inside possible,rod bearings or crank bearings. if it sounds to be coming from the top of head it may need valve adjustments. if u put it under a load ,and it gets loader,bearing should be looked ,at if it stays the same ,look at the valve adjustments.
Jul 11, 2010 | Honda CB 700 SC Nighthawk Motorcycles
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
Logitech R-20 Computer Speakers Logo
42 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
