Question about Maytag Neptune FAV6800AW Top Load Washer
The barrel wobbles so bad it kicks off the machine with error UD
All at once, this Neptune TL FAV6800AWW failed to spin out on any cycle due to excessive wobble. This machine has an auto load balance feature and goes thru it about 3 times before quitting. Changing the position of the clothes in the machine does not apply.There is not any excessive noice other than wobble.
The two front struts and the two rear struts seem OK. Everything else looks fine. The machine will spinout without a load but a single item inside will cause failure.
I assume the problem to be the struts but which ones and why would they fail all at once? I do not think electrical is a problem and the transmission is quiet and seems to be working OK. There is a tick as the barrell starts to spin but even that goes away with speed.
What could be wrong?
  • 335 Answers
This was my issue several weeks ago, very common problem with the FAV6800AWW.
""I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley, just follow the service manual removal steps to remove the clutch pulley. Pull the plastic cover off the clutch pulley and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 4 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found a link on this site, good luck""
Posted on Jan 16, 2009
Have Neptune FAV6800AWW top load, washes when it gets to the rinse cycle it stops with water in. If we remove the clothes and wait a while we can get it to complete. The code we are getting is DR which...
Are you sure the error code is DR? Could it be DC an unbalance error code. Google ""16022808.pdf"" to find. Is the washer banging around in Spin Cycle? If so this is a Clutch Pulley issue.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
DR is not a listed error code in the FAV6800A/FAV9800A Service Manual.
Aug 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Once washer hits spin cycle (12 min. left) it throws a DC code. Checked the TDS sensor - OK, motor control - OK, spinning the tub by hand in CCW feels smooth. Haven't taken apart to clean and lube...
This is a Clutch issue.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and owner repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues (this issue) that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
I can
Apr 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune tl fav6800aww starts, then I believe at th first spin cycle starts then stops. Then it starts a loop of this process and never continues on. No error codes are displayed. When I open the lid...
Open the washer lid and see if you can rotate the wash basket CCW this is the Spin direction.
The wash basket should not rotate CW. If the the wash basket will not rotate CCW then I feel the One-Way Roller Clutch bearing is seized. If you place the washer cycle in a Spin Only cycle I believe you may see the same fail process with no error code.
If you want to DIY the fix Google this Neptune TL Washer FAV6800AWW. That will take you to a FAV6800A Sticky.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
I feel you will find that the Clutch has failed due to a leaky Tub Seal. A replacement Clutch Pulley will more than likley get you back in service. Once you have the Service Manual you can pull the front cover off drop the Clutch Pulley out and inspect.
I won't offer any more help on this site it is just to difficult to work issues. You can see by past ratings I know the machine and have helped owners. If you are not the DIY type then callin in a Service Repair will cost $65 to $90 range and more than likely they will not have a clue. Go thru the FAV6800A forum here and search the post. i.e. this is typical repair service result for support........ http://www.fixya.com/support/t8683813-6_year_old_maytag_neptune_tl_washer_just
Not hammering service people, most just don't have the hands on knowledge to diagnose machine issues. Once you know the fail point anyone that has very basic mechanical skill sets can repiar the machine. Go to the forum that has the Sticky and open up an issue in the Maytag washer part of that forum and I will help. I scan the forum a few times a day. If you are not into a DIY fix just disregard this post.
Apr 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
180 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
