Water remains in bottom of dish washer.kitchen aid whisper quiet+
  • 15,935 Answers
There is supposed to be some water at the bottom to keep the seals moist.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whisper quiet plus kitchen aid manual
Hello, As You Wish -
It looks like you can obtain the owner's manual for your Kitchen Aid dishwasher through the Kitchen Aid web site. It will probably be a download option for a PDF version of the manual. This is the link: https://www.kitchenaid.com/customer-service/manuals/ . You will need to enter the model number of the dishwasher.
Note: When I obtain a downloaded PDF user manual (for anything), I create a file in my Documents folder, giving the file the name of the product, so I can find it easily. Example: Kitchen Aid Diswasher. Unless the manual is hundreds of pages long, I also print it out and keep it in a paper file folder with other appliance and equipment user manuals.
Best wishes.
Dec 18, 2017 | Dishwashers
Kitchen aid whisper quiet, model KUDI02CRBL1, leaking water from under the door. Changed the tube door seal, the bottom strip of plastic running across the door on the bottom and today a new soap disp....
Suspect the door latch has loosened enough to allow water spray to get into the latch cavity. Look for worn parts or loose adjustable components in the latch area (both door and case sides). Hope this helps!
Sep 18, 2010 | KitchenAid KHWS01PWH Global Horizontal...
Dishes are still dirty. I have used every kind of dishwasher aide, half loaded it and dishes are still dirty, I let the water run until very hot before starting the washer. The washer says you don't have...
Suggest the problem may be a plumbing issue - likely substantially blocked drain system, so the dirty wash water cannot properly pump out but rather remains in the dishwasher.
Suggest getting a plumber in to "snake" out your kitchen drain system. You will probably notice your sink drains will suddenly work much better too...
Aug 02, 2010 | Dishwashers
Dishes do not come out dry and this has just begin happening.
I'll assume you refer to a dishwasher and not a PC. If the internal pump does not get all the water out, then the resulting pool in the bottom will inhibit the dry cycle. When it has reached the end of the washing cycles, open the door and see how much water is left. Then you will need to find out why that is, if there is a lot remaining. Could be a clogged screen on the pump.
May 26, 2010 | Enermax 431W Ultra Quiet ATX Power Supply:...
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Kitchenaid Superba Whisper Quiet Ultima: It won't drain. I returned from a trip to find a puddle of water in the basin/reservoir, which usually drains during a normal wash/dry cycle. Now it'll shoot out...
Not familiar with that model, but one time I found a baby sock jamming the water outlet in a dishwasher, so check to make sure there's no foreign object blocking any exits. Other than that, I suspect it will need to be serviced, or at least taken apart for further inspection.
Mar 13, 2010 | KitchenAid Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
