Question about D-Link AirPremier DWL-3200AP 802.11g/b (790069273544) Wireless Access Point
Cannot Access My DWL-3200AP
I really need yr help, i have DWL-3200AP but i can not access it, i tried the default IP but not working, then i make a reset (pushing the reset bottom and hold 10 sec) but also did not work.
for information i can access the inter net via the wirless connection with DWL-3200AP.
appriciate you fast response
  • 1 more comment
  • m_shemy Jan 17, 2009
    i tried the above and i got the default gateway is 10.0.0.138 but this ip belong to my speedtouch not the Dlink.
    plz i am still can not access my DLink, any other solution
    i tried the above but it does not work, i got the default gateway is 10.0.0.138 and i typed in IE but it access me to my speedtouch not Dlink.
    plz i am still cannot access my DLINK, need Help
  • nsugar May 13, 2009
    Cannot Access My DWL-3200AP, with the default ip, 192.168.0.50.
    I make all instruction from the manual.
    Sergeant:
  • 366 Answers
If you can browse internet via same device
Start/ Run/ CMD/ type "ipconfig" (w/o ")
Use default gateway IP address as your AP ip address..
Enable java and use IE (some devices prefere IE)
e remember to score this tip.
Posted on Jan 16, 2009
  • Pat Batta
    Pat Batta Jan 20, 2009
    From user manual:
    1. To configure the DWL-3200AP, use a computer which is connected to the DWL-3200AP with an Ethernet cable (see the Network Layout diagram).
    2. First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
    3. Start your web browser program (Internet Explorer, Netscape Navigator™).
    4. Type the IP address and http port of the DWL-3200AP in the address field http://192.168.0.50) and press Enter. Make sure that the IP addresses of the DWL-3200AP and your computer are on same subnet
    Of course: Note: If you have changed the default IP address assigned to the DWL-3200AP, make sure to enter the correct IP address. (or you can reset device to factory default using the reset button on the back of the unit)
  • Pat Batta
    Your cable must be connected via POE device be sure to plug according to schema:
You could download the dwl 3200ap manager.with this you could set your password and ip..later on download a new firmware and upgrade your accesss point
Posted on Aug 23, 2010
  • slaguda Nov 02, 2011
    This worked for me, thanks!
  • Bhanush Arora
    Bhanush Arora Dec 21, 2013
    which access manager did you use? I am facing the same problem , cannot get anything to work
How to confiration my Dlink DWL-3200ap access point plz help me
plz send me PDF file
Posted on Jan 11, 2010
    Scholar:
  • 59 Answers
The IP should be the same as your default gateway.
run>cmd>ipconfig /all
Try turning off your wifi and plugging into the router with an Ethernet cable then point your browser to the router's IP. This should bring up a login prompt if the problem is that wireless administration is disabled by default.
Posted on Jun 13, 2009
Default password dlink 3200AP
Is it printed on the bottom of the router?
Sep 11, 2012 | D-Link AirPluseXtremeG® DWL-3200AP...
One dlink 8port switch & 2 qut ( 3200ap wifi ) how to configer D-Link DWL-3200AP wifi to wifi
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 08, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
D-link dwl-3200ap not given the right default address which is 192.168.0.5 instead give an ip of 169.254.16.219 and no default gateway given, it's blank
Try to reset the network adapter. This can be done by finding the network and right-clicking it and selecting Diagnose.... It should give a few options, select Reset network Adapter.... If that doesn't work, consult D-Link Tech Support....
Jan 08, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
I want to extend 2640t router's range by using 3200AP as wireless extender. Could establish handshaking between two devices using physical (cat6) cable but not wireless connectivity. In which mode 3200AP...
yes u can just use the same range ip address for both device like 192.168.0.1 for dlink and 192.168.0.2 dor airplus.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2010 | D-Link AirPremier DWL-3200AP, AirPlus G...
How to configure a D-link access point DWL-3200AP
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | D-Link AirPremier DWL-3200AP 802.11g/b...
My D-link 3200AP don't show signal
check the drivers and the capabilities of the second laptop
Dec 25, 2009 | D-Link AirPremier DWL-3200AP 802.11g/b...
Wireless AP is not broadcasting
i have several of thees routers they do not asine ip adresses
conect them to a router that assignes an ip
mine are hooked up to the network via a linksys sisco rv082
and they work real good
Apr 07, 2009 | D-Link AirPremier DWL-3200AP 802.11g...
After resetting the Access Point i cannot login to admin account
You need to reset the AP to factory default (keep the reset button pressed while powering up the unit).
Nov 15, 2008 | D-Link AirSpot DSA-3200 (F56772) Firewall
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPremier DWL-3200AP 802.11g/b (790069273544) Wireless Access Point Logo
9,904 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
