Question about Logitech QuickCam Express Web Camera
Logitech software not working
My QuickCam will take photos through My Computer >Camera and scanners -USB device. It will also works for video if I right click on the icon and use the Tool-Amcp8.exe. But through the Logitech software it says the camera is not connected and reconnect does not work. Obviously the camera is working and the USB ports accept the camera. There are no updates for the software and it is a brand new camera. My older one works just fine.
My cam is not working but its saying usb is not regonised
Posted on Jan 16, 2009
My video stopped working on my Logitech QuickCam Pro 9000. No picture or video. I just used it last on Tuesday and now nothing. I even reinstalled the software..still nothing. Help!
Check if the device enumerated
click on Start
Computer > right click > manage > Device Manager, click on it
You should see in "Imaging devices" a "USB Video Device".
If not then device did not enumerate.
If you see a yellow circle in "oher devices" try to updated the driver by clicking on it.
Mar 22, 2010 | Logitech QuickCam Pro 9000 Web Cam
I cannot preview my video on my quickcam orbit mp
check the dm for enumeration, if the cam is present under imaging devices. uninstall all of the logitech software and plug camera in without the software. cam should come up generic USB device the try to preview in skype. if workinf reinstall sotware from the logitech websight.
Jul 10, 2009 | Logitech QuickCam Orbit MP 961422-0403...
When i hook up the USB in computer it shuts down
Reinstall or update the usb devices drivers.
doesnt work? try changing power supply
May 28, 2009 | Logitech QuickCam Orbit AF Webcam
QuickCam 5.3 and Vista
If you have the Original Installation CD for the Device.
Try installing from The CD.
If not try add/remove from the device manager.
if it,s USB Try, installing in A Different Slot ( Hub )
Look in the sys/devices to see if The Hardware has a Driver Problem ( yellow Exclamation Mark ) if so remove the device.
reboot computer, let the computer detect, and install.
Thankyou For using fixya.
Mike @ Compurepair.
Jan 19, 2009 | Logitech QuickCam Express Web Camera
QuickCam Zoom not working after upgrade to Vista
Just read the most wonder article on how toe fix your quickcam zoom for vista follow these steps
These is from 2007 post so you will have to google for the drivers mentioned. I did and it worked
I have a Logitech Quickcam Zoom and this is how I got it to work:
1. Install QuickCam 32-bit Version: 10.5.0 Build 1096b
It can be found here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=10234
2. When you get to the camera detection part where it asks you to plug in your camera, plug it into a new usb port (if you had it plugged in when you installed Vista) and just press skip.
3. Windows may try and find the driver for it, you can cancel that too.
4. Install the old QuickCam software (Version: 8.4.8 build 1034A)and overwrite anything it asks you to (it will fail to install completely because of the new version, but it will put the files you need into the Logitech program files directory.
The old software is here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=7649
5. Go to the windows orb (former start button), open control panel, go to system, then on the top left of the window click device manager.
6. Find the unknown usb device (hopefully you only have one... otherwise unplug anything else that doesn't work or you haven't updated the driver for yet)
7. Right click and select update driver, choose a location to find the driver, navigate your way to C:\Program Files\Logitech\QuickCamWebInstall\Drivers\WinNew\PRO2
8. Press OK or whatever, and let it install.
9. Enjoy!
Mine didn't even need to reboot and worked with the 10.5 QuickCapture software. Still need to test with Skype and Live Messenger though.
Jan 08, 2009 | Logitech Quickcam USB Zoom Webcam
Logitech quickcam express problem soft
i require new driver for quickcam express 2 web cam please, know where to find one?
Oct 02, 2008 | Logitech QuickCam Express Web Camera
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
Can't use it at all really.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 03, 2007 | Logitech QuickCam Fusion Webcam
Logitech QuickCam Express Web Camera Logo
96 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
