Question about Garden
The pump lost vaccum, now the motor shut off and pump only hums.
The pump only hums when power is put to it. I believe the pump was on alday and lost vaccum, now the motor does not come on.
  • Julie Mitchell Sep 27, 2012
    WaterWay pomp HP2.0spl, no power is getting to it. Checked braker panel all good there. There is power to the point of wire to the pump but pump won't turn on. No sound all dead, any help out there?
  • 565 Answers
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Posted on Feb 05, 2009
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do you reset spa motor/pump?
Most of the motors have an internal device called a clixon that detects excessive current and shuts off the motor. It then turns it on again when it cools off. If you wait and wait and there is power for sure at the motor terminals and the motor is not even humming then there is a problem in the motor. If it hums for a few seconds and quits humming for a while then the motor capacitor is bad or the motor is bad. I hope this helps.
Aug 13, 2011 | Pool & Spa
Why does my jet pump not start when the pressure switch cuts in it just hums and turns very slow till the thermal overload switch shuts it off. I you drain the tank it starts fine
Not many specifics to go on so I can't be too specific with a fix, but most of these type pumps use a capacitor start motor, if and/or when these capacitors go out, the motor will start hard or just hum until the thermal overload safety switch opens. Disconnect pump from power, open the capacitor cover and check for an indicator spot on the terminal end of the capacitor, if its other than white, the capacitor has been hot and needs to be replaced. If there is no indicator try replacing the capacitor anyway, they don't cost much and should be readaly available. The other common fault is a "lost leg " on a 240 Volt circuit, check for a blown fuse (one of two in the disconnect. If your not comfortable and experienced around electricity,Remember: if you don't kill the power, it can kill you ! Call an Electrician.
Dec 21, 2010 | Plumbing
We just went thought a freezing snap. Now everything has thawed but my hayword pump just hums for a few seconds then shuts down for a few minutes and hums again. Is the pump shot? Thanks Dave 12/17/2010
Chances are you have lost the start windings on your motor coil. A frozen motor can also be cause by a swollen motor shaft due to a leaking pump seal. If the wet-end part of the pump is in decent condition you can have just a new motor and seal installed. Its always better to buy a complete new Pump with factory warranty.
Dec 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pump acts like it is froze up. It hums and smells like it is burning when it runs. It hums then shuts off, hums then shuts off?
Either you need a new start/run capacitor or the bearings have seized. If it's been running loudly recently, the bearings have probably seized. If not, the start capacitor is probably bad. This can sometimes happen when the motor windings start to develop a short. If you replace the capacitor and it blows again, you'll probably need a new motor.
Oct 22, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Whisperflo Pump 1.5 Hp problem
The pump is probably fine the motor is the problem. If it just hums it might just be the capacitor on top of the motor. Don't know how long it sat there not able to start. Was the motor extremely hot ? If it got too hot may have damaged the motor. Motor is replaceable without replacing the pump head.
Sep 30, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Pump does not turn on except for a humming sound and shuts off jumping the electric breaker
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
Jun 02, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Kitchenaid dishwasher KUDS01....
the pump is stuck. remove motor.insert plastic pen into bottom of motor.remove impeller by turning counter clockwise.file bottom of impeller stem.put enough washers on the keeper clip to prevent the impeller and the pump housing from binding.reassemble and there you have it!!!!
May 23, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Garden Logo
619 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
