Question about Beckett Water Gardening Beckett Statuary Pond Pump, 250 Gph
GFI for pump keeps tripping...
The GFI that my Beckett pond pump is plugged into, keeps tripping, but will pump for say, 15 seconds before it trips off. When we unplug the pump, the GFI stays in the "in" position and does not trip. We have tried plugging the Beckett pump into other outlets, and it does not work. Does this mean there is a short in the pump or in the electrical system??? Kathy in Tucson
  • 1 more comment
  • higgikd1 Jan 16, 2009
    Joe - I have had the pump for awhile, bought it new. It was in the pond working fine, and this problem just occurred. Actually, since I have written the question, we took the pump OUT of the water and are letting it dry out to see if it will work.
  • Joe Neff May 11, 2010
    Is this a new pump or is it a problem that just started? Is it a new GFCI outlet? Joe
  • David Gillis
    David Gillis Dec 05, 2012
    try puling the GFCI out of it's box, use electrical tape to wrap the outlets teminals and grounding connectorss. GFCI's are very sensitive to it's hot, neutral and grounding location within a metal box.
  • 547 Answers
No you need to put 60amp breaker in house panel box
Posted on Feb 12, 2009
  • David Gillis
    Only if you want to burn the house down. A 20A GFCI maximum overcurrent device is 20A providing it is wired with #12 copper if they used #14 copper wiring the max overcurrent device is 15 A
Does the plug on the pump have a fuse inside
no fuse check breaker possibilities are bad gfi ,wiring short , pump seized or stuck
Aug 14, 2016 | INTEX Sand Filter Pump
Pump keeps tripping gfi outlet
That means the GFCi is doing what it supposed to do...shutting off the circuit in the event of a fault. Repair or replace the pump. You can plug something else into the GFCI to test the outlet itself
Mar 21, 2012 | Little Giant Water Wizard 5msp 115v 60hz...
Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Jun 10, 2010 | Little Giant Plumbing
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Pump was tripping the it wont work at all
My pond pump had to be replaced after three years. They said the fine grit out of my fish pond. got into my bearings and cut them out.
Nov 06, 2017 | Savio Water Master Solids Handling Pond...
Our hot tub keeps tripping the gfi breaker, but if we don't put it on a gfi then it works fine. How do you fix this
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Apr 19, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
Beckett Water Gardening Beckett Statuary Pond Pump, 250 Gph Logo
1,409 people viewed this question
Top Beckett Water Gardening Garden Experts
Dennis Key
Dennis Key
john h
Are you a Beckett Water Gardening Garden Expert? Answer questions, earn points and help others
