Question about Acer Aspire One PC Notebook
Hello my acer aspire one when i put it into sleep mode or have been using it for several hours it will loose its wi-fi connection. The connection prior to this is very high but it for some reason looses it and when i search for a wi-fi location it doesn't pick any up even when i am beside my router. My question is how do i solve this problem? Thank you andrew
  • 32 Answers
Notebooks are notorious for problems with internal wifi. When I first encountered this problem years ago, I spent over 30 hours researching and testing various solutions.
Here are some work arounds which I have used in the past successfully.
1. If there is still a warranty coverage and you can go without this computer for some time, send it to the manufacturer. They may replace the board and restore you to what you to a place of comfort.
2. Purchase a new or refurbished USB wifi. I have acquired online or at stores such as TigerDirect.com refurbished USB wifi for as little as $10.
If you purchase a USB wifi you will still be able to use your internal wifi. However, when it fails, you will have the option of inserting the USB wifi. I suggest that when you insert the USB that you shut down your internal wifi. If both are operating there is a tendency for the system to slow transmissions somewhat.
If you decide to troubleshoot your problem to come to your own resolution you are likely to end at a point of frustration. You will find a workaround a better approach.
Posted on Jan 19, 2009
After charging my IPAD says IPAD is disabled and underneath it says connect to iTunes. what do I do?
Try putting it into DFU mode which is
-hold sleep/wake and home button untill it turns off
-let go of sleep/wake button still hold home button for about 10 seconds
-plug it up to iitunes
-and it should be there
Dec 30, 2015 | Apple iPad Air 9.7" 32 GB Wi-Fi Space Gray...
Hi My Smart phone Kikka when i send whatsup massage it take more tha an hour to reach
Try the following it relates to both sending and recieving, posted by the whatsapp team.
Make sure to have a strong internet signal on your phone
Make sure your phone has an internet connection. You can check this by opening a browser and going to a website. If you're having connection problems, try these connection steps.
If web pages work, but WhatsApp doesn't, you will need to contact your mobile provider and system administrator and make sure that your APN and router are configured correctly to allow non-web and socket connections.
You may just need to change the notification settings in WhatsApp
  1. Open WhatsApp.
  2. Push the Menu Button.
  3. Tap Settings > Notifications.
In this menu, you have options for Message Notifications and Group Notifications. Adjust the settings to your liking.
If messages are still taking too long to reach your phone
It may be that you are not receiving your message pushes from Google's push notification service.
We recommend that you:
  • Reboot the phone (Turn it OFF then ON).
  • Try to install Push Notifications Fixer and see if it helps.
  • Delete and reinstall WhatsApp.
  • Make sure that Background data is allowed under Settings > Data Usage > Menu Button.
  • Launch the Hangouts app, press the Menu Button, and sign out of all of your accounts (tap the account, scroll down and select Sign out). Then re-launch Hangouts and sign back in to your account(s).
  • Turn off Wi-Fi.
  • If you are often connected to Wi-Fi, check your Wi-Fi sleep policy (Settings > Wi-Fi >Menu Button > Advanced > Keep Wi-Fi on during sleep) and make sure it is set toAlways.
  • For Android OS 4.4 and above, make sure that Wi-Fi optimization is unchecked (Settings > Wi-Fi > Menu Button > Advanced > Wi-Fi optimization).
  • For HTC devices, try turning off fast boot in Device Settings > Power > Fast Boot(make sure it is unchecked). You may also try turning off Power Saver, Extreme Power Saving Mode and Sleep Mode. Make sure to reboot your device after changing the settings to ensure the changes are applied.
Mar 09, 2015 | Cell Phones
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
I hav e an Acer Aspire 5742G model. The Wi-Fi works well, but then I can't get the bluetooth to work. What might be wrong?
Hello there,
The bluetooth of the acer aspire 5742g model does not work on its own. It requires you to connect a bluetooth dongle on to it via the usb port. Then you will be able to use the bluetooth of the laptop.
Try it out and see.
Hope this was helpful to you. Goodluck Elect_Comp
Aug 30, 2011 | Acer Aspire 5742Z-4200 Notebook
Does acer aspire 5742 have wi-fi
Actually, Wi-Fi is another term for Wireless Network. Well, the answer to you question is Yes, it is a wi-fi ready machine. You don't need any additional hardware to access a Wi-Fi network, in other words, it is a wi-fi certified machine. Hope this helps.
Good Luck.
Thanks for using FixYa.
Apr 11, 2011 | Acer Aspire 5742Z-4200 Notebook
Acer aspire one notebook wont connect to my wi fi it was fine before
Try system restore.
Go to start - All programs - Accessories - system tools - System restore.
Try to restore your system to an earlier time - time or date when your system is still able to connect to your wi-fi router.
^_^
Jun 06, 2010 | Acer Aspire One PC Notebook
How do i switch on wi-fi on my acer aspire 5735 laptop ?
Check in your laptop you find wi fi switch turn it on.
then check in device manager that your wi fi driver is installed and enable.
then view for wi fi networks then you find your router if it is in range connect into it.
let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | Acer Aspire 5735 Notebook
Acer wireless dirver for XP
This model has one of two makes of Wifi card/chip installed its either;
1 Intel® Wireless WiFi Link 4965AGN (dual-band quadmode
802.11a/b/g/Draft-N) Wi-Fi CERTIFIED® network
connection, supporting Acer SignalUp™ with InviLink™
Nplify™ wireless technology
or
2 Intel® PRO/Wireless 3945ABG (dual-band tri-mode
802.11a/b/g) Wi-Fi CERTIFIED® network connection,
supporting Acer SignalUp™ wireless technology
If you have the incorrect driver it wont install
Hope this helps
here are the links for you to download the correct ones
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Atheros_%207.2.0.215_VistaX86.zip?acerid=633639023394558300&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
and
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Broadcom_%204.170.25.19_VistaX86.zip?acerid=633639023397522319&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
Aug 10, 2009 | Computers & Internet
Wi-fi not working
my acer orbicam won't work
Aug 07, 2008 | Acer Aspire 4720 Notebook
Acer Aspire One  PC Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
