Question about HP 510 Notebook
Windows is in a coma. userinit.dll refuses to load when xp home boots up (splash screen ok then dialog box alert) i have cd part code 409456-022 but that requires windows to be working, i need a fix for the level above that....
    Problem Solver:
  • 82 Answers
Reinstall the Operating system......................Sameeraryan
Posted on Jan 17, 2009
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
An internal application error has occurred
Method 1: Reregister Jscript.dll and Vbscript.dll
  • Click Start, and then click Run.
  • In the Open box, type regsvr32 jscript.dll, and then click OK.
  • Click OK.
  • In the Open box, type regsvr32 vbscript.dll, and then click OK.
  • Click OK.
If either of the files do not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Microsoft Windows XP, follow these steps:
  • In the Open box, type msconfig, and then click OK.
  • Click Expand File.
  • In the File to restore box, type the name of the file that you want to restore.
  • In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or
    click Browse From to locate the Windows XP .cab file.
    Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  • In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
  • Click Expand.
  • In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method.
Jun 14, 2011 | Microsoft Windows Media Player
Computer loads personal settings and then logs off instantly
Sounds like a malware issue I've seen before:
XP logs user off immediately when the user tries to log in - can't get to any desktop
Allegedly 3rd party advertising software Blazefind (homepage and searchbar highjacker)
Fix:
Boot to the Windows XP CD (RAID systems will need the RAID driver floppy during the bootup - hit the F6 key when directed in the bottom message).
Enter the Recovery Console by choosing 'R' at the Welcome to Setup screen.
Choose the OS shown (1) and hit enter.
Hit enter for a blank password if asked for one. If this isn't accepted, make sure that the user is using the correct XP CD (using a PRO version CD for a HOME version install or visa versa will result in a password rejection. If the user has upgraded to PRO over a HOME edition, try booting the HOME CD). If the CD is correct, and the user can't produce the correct Administrator password, then a clean reinstall of the OS (with full data loss) becomes the final answer.
Assuming the user now sees a command prompt, type "CD %systemroot%\system32" (without quotes) and hit ENTER. Normally the %systemroot% default is "c:\windows\" but this depends on if the system defaults were kept or changed during OS installation, of course.
Type "COPY USERINIT.EXE WSAUPDATER.EXE" (again, without quotes) and hit ENTER. This makes a copy of "userinit.exe" and simultaneously names the new copy "wsaupdater.exe".
Type "EXIT" and ENTER. Remove the XP CD while the system is restarting.
The user should now be able to log in normally... but there is one more thing that needs to be done or the issue will repeat itself when the user runs his anti-spyware program again.
Once logged into an administrator account, click the START button.
Choose RUN from the Start Menu.
Enter "REGEDT32" in the OPEN window (notice there is no "i" in edit) and click OK.
By clicking on the + signs next to each branch, click through the tree in the left pane until you get to
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\WINLOGON
Click on the WINLOGON folder in the left pane tree, so that it is highlighted.
Look for "UserInit" in the right pane. It should have a value of "C:\WINDOWS\system32\wsaupdater.exe," (yes, there is a comma at the end of the value). Double-click on "UserInit" and carefully change its value to "C:\WINDOWS\system32\userinit.exe,". Click OK.
Close the Registry Editor. Reboot. Fix is complete. Anti-spyware programs will probably identify and remove "wsaupdater.exe" but the system is no longer using it.
Jan 27, 2010 | Dell Inspiron 6000 Notebook
When i turn on my computer it loads up and everything but it just go right back to the windows xp page so im not able to do anything what do i do ?
The most likely cause is that you either lost your USERINIT binary, or Windows is looking for it somewhere else. Both may be caused (and usually are) my a virus or malware.
The simplest solution is to run a repair install from the XP Boot CD.
If the USERINIT was simply misplaced or removed, it is possible to recover it by:
- booting the system from XP boot CD-ROM
- clicking R to enter the recovery console
- running the following command:
expand d:\i386\userinit.ex_ c:\windows\system32
- as soon as the file has been expanded and copied, type "Exit" to reboot the system.
This will recover a faulty USERINIT, but won't be able to fix a wrong userinit pointer in the registry. To do that you need a repair install:
http://www.geekstogo.com/forum/How-to-repair-Windows-XP-t138.html
Jan 22, 2010 | Acer Aspire 3610 Notebook
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
How will i restore deleted userinit file in system32 folder?
Insert the original Windows XP CD (Windows XP with Service Pack 2 is preferred, but not required) and reboot the computer. You may need to configure your computer to boot from the CD-ROM drive.When the Windows XP Setup has started, press "R" to "repair the Windows XP installation using Recovery Console".
Select the Windows installation to repair (generally this is C:\Windows) by typing its number and then pressing ENTER.
Type the Administrator password and press ENTER.
Type the following commands:
D: [ENTER]
CD I386 [ENTER]
EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32 [ENTER]
NOTE: If your CD-ROM drive has a different letter assigned to it, enter "X:" instead, where X is the appropriate drive letter.
After entering "EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32" you should see the text "1 file(s) copied", in which case all went well.
Remove the Windows XP CD, type "EXIT" and press ENTER to restart your computer. You should now be able to log on as normally.
Mar 05, 2009 | Microsoft Windows Vista Home Premium with...
BLUE SCREEN W/ MESSAGE STOP: C000007B BAD IMAGE.
Try to look for your windows xp cd.
Turn the computer off. Restart it and start tapping f12 right after.
Insert the cd. Choose the option that says CD/CDRW/DVDRW from the screen and press enter. Watch out for a prompt that will say 'Press any key to boot from cd'. press any key as soon as you get this. If you miss it, you'll get the error again. You should get the blue windows setup screen if you caught it at the right time.
Wait until you get the 'welcome to setup' screen.
Press R.
Follow any other instructions that you may get until it gives you the C:\> prompt.
Type in bootcfg /rebuild.
Below is a listing of the common steps you are likely going to encounter.
* Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
* Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition". If you have Windowx XP pro edition, enter 'Microsoft Windows XP Professional'
* Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
Then type 'exit'. and let the computer reboot. If you get two options for microsoft windows. Choose the one that says what you entered when you were in the recovery console.
If you are able to boot correctly after those steps, go to start>click run. Then type msconfig. Click ok. Click the boot.ini tab. Click 'check all boot paths'. Click ok or yes. click close and restart if prompted. You shouldn't get the prompt for two microsoft windows anymore.
Jan 02, 2009 | Dell Inspiron 1300 Notebook
Error: C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
Hi
Hey dear its a virus, luckily your antivirus has already removed it from your pc. one trace is remains in registry which will try to load it on startup.
Ok, do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it.
Ok thats all. restart your system .
Sep 17, 2008 | Microsoft Windows XP Home Edition
HP 510 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
