Question about Xerox Phaser 7750DN Laser Printer
Im running 12"X18" sheets from the manual feed tray..
I'm getting some red spots on the image they're 3 3/4 away from each other.. going to the tail of the shet on the same direction
    Novelist:
  • Xerox Expert
  • 297 Answers
You should print the "Repeating Defects Page" Using the printer's front panel menu keys perform the following steps:
  1. With Information highlighted, press the OK button.
  2. Scroll to Troubleshooting by pressing the Scroll Up or Scroll Down button.
  3. Press the OK button.
  4. Scroll to Print Quality Probelms by pressing the Scroll Up or Scroll Down button.
  5. Press the OK button.
  6. Scroll to Repeating Defects Page by pressing the Scroll Up or Scroll Down button.
  7. Press the OK button to print the Repeating Defects Page.
Most likely you have a defect on your magenta imaging unit. Switch the Magenta and Cyan imaging units and try the test print....if you have blue spots 3 3/4 then it is the imaging unit (drum). If not you may need to change the belt cleaner assy.
If it isn't the imaging unit then it will be a problem with the fuser rollers, so replace the fusing assembly.
Posted on Jan 16, 2009
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
Printing 12 x 18 from tray 4 Every 2nd sheet jams.
MAKE SURE YOU SET THE THICKNESS SETTINGS AND OTHER SETTINGS ARE CORRECT, MAKE SURE IT IS 12 X 18, CLEAN THE FEED TIRES WITH WD 40 THEN RUBBING ALCOHOL, MAKE SURE ITS DRY BEFORE FEEDING PAPER
IF YOU HAVE A TRAY 5, ITS MORE RELIABLE
IF STILL PROBLEM HAVE YOUR TECK USE THESE PARTS
A03X565300 FEED AND TAKE UP ROLLERS
A03X565400 SEP ROLLER
56AA82012 BOTH CLUTCHES
AND TRY UNPLUGING TAKE UP ROLLER PICK UP SOLIENOID, WELL IT SHOULD WORK BETTER, AND MAKE SURE YOU DO THE BOTH SIDE ADJUSTMENT, WITH OUT SEEING EXACTLY WHAT THE COPIER IS DOING THIS IS MY BEST ANSWER
Aug 24, 2013 | Konica Minolta Bizhub C5500 C6500 C5501...
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Im getting an error mp5100, after a paper jam that was removed and the error continues even though I turned the printer off several times
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch
Oct 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
My printer is blinking red and there's no paper stuck in it what do I do
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Aug 16, 2010 | Brother HL-2040 Laser Printer
The paper is jammed. How do i get it out?
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jun 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
Where is Jam 2 located
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 26, 2010 | Brother HL 7050 Laser Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
WILL NOT PRINT LABLES
Maybe you have the type of file blocked on your printer/computer. If not im not sure what the problem is..
Mar 08, 2008 | Brother HL 5140 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
