Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Problem when connected to the e-sata port of two dif. computers
Dell XPS 420 with Vista Ultimate SP1
When booting, the Intel Matrix Storage Console reports that the FAPro 500GB "may fail in the near future... etc". It then works fine but the same message pops up every few minutes. The same when connected to another computer.
No problem when connected to firewire or USB ports, but it is obviously much slower.
On firewire or USB connections, chkdisk does not report anything wrong but, I badly need the faster copying of the e-SATA2 interface, the very reason I purchased it. Help please!!!
FreeAgent Pro USB/eSATA/1394
S/N: 5QM1SZ06
  • 98 Answers
I think we a re talking about SMART technology, that is disk is telling you that something's wrong. If you have a guarantee, return it to reseller and ask for another one.
Posted on Jan 15, 2009
Dell xps 420 black screen after intel
Computer blue screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive . They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are few free software for you to use, so if you want to take this solution money is indispensable. Windows Boot Genius owns a better cost/performance among other kinds of software I've used. It may be a good choice for you if you have money to pay.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
source:http://www.reset-password.net/black-screen-of-death-and-blue-screen-of-death.html
Jan 16, 2013 | Dell XPS 420 PC Desktop
Sata port 2 does not work
Remember always downwards compatible as a rule of thumb. You may not be able to connect a SATA 3 drive into a SATA 2 port.
Ports 2 and 3 are SATA 2.
http://support.dell.com/support/edocs/systems/xps8300/en/sm/techov.htm#wp1268982
GL
Nov 12, 2012 | Dell Xps 8300 Desktop Computer (Intel CORE...
My computer wont boot up
check your cables,your hard drive is not detecting
May 09, 2012 | Dell Inspiron 530 Desktop Computer...
When i try boot my dell xps 420 it states that there is no boot device available. Why does it say this?
A boot device stores your operating system (i.e. Windows), and is usually your hard drive, but can be any storage medium such as a floppy, usb flash drive, or even a cd rom. When you turn your computer on, your motherboard looks for your OS on any of the storage devices specified in your bios, in the order specified to look first (Ex. Boot order: 1. CD-Rom, 2. Floppy, 3. Hard Drive, 4. Network). Your Dell is telling you that it can't find Windows on any of these devices. Most likely cause is that your hard drive stopped working, your Windows boot.ini file became corrupted, or you have a USB device plugged into your computer, and it needs to be unplugged before turning on your computer.
Jul 05, 2010 | Dell XPS 420 PC Desktop
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Help My Sandisk U3 Locks up vista SP1 useing intel 920i
Very well could be due to the fact your running 64bit Vista. I would try shutting the computer off,connect the U3,then turn on the computer. Sometimes the drives come with software that could be causing the problem also due to the try to install themselves when connected. You could also try booting up in safe mode. Press F5 repeatedly when the computer is booting up and this will take you to a menu that you can choose the safe mode option and try to connect the drive in this mode. You can then load/disable files or software on the drive that may be the cause of the problem. Also try the drive in another computer if possible and if it works try getting the firmware update from the sandisk website. It is possible the drive itself could be bad.
Sep 04, 2009 | Dell Studio XPS 435 PC Desktop
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
83 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
