Question about Rangemaster Kitchen Hood
Need a motor for an old Rangemaster vent hood. where can a find?
The old motor is an Aubrey no 7163-3855. double shaft 5/16
    Champion:
  • 244 Answers
Repairclinic.com
Posted on Feb 12, 2009
I have a 4 year old RM5200 hood over my stove. The motor is making a whining noise. It seems to soon for this to happen. It is loud and constant to the point where we don't want to use it. Is it time...
Range hood motors, bathroom exhaust fan motors all share the same thing. They become coated with grime inside the shaft of the rmotor due to their exhaust feature of sucking dust and grime over the motor, which is open. The only solution is to get access to the motor and clean the fan blades and squirt a little WD-40 down the shaft as that is where the noise comes from. The dirt and grime build up on the motor shaft, and eventually starts rubbing the bushing where the shaft rest and makes a noise. Yo must remove this from the shaft and allow a little play, and lubrication which the WD-40 will supply.
Feb 15, 2011 | Rangemaster Kitchen Hood
The fan motor makes a noise but doesn not start rotating, if you rotate the fan the motor kick in and continues to work until it os turned off.
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Jan 17, 2011 | Broan-NuTone Broan Range Hoods Rangemaster...
For the last few months my vent hood's motor has been making a lot of noise whenever it was in operation (making a squeeking sound like it needed to be oiled). Then it simply stopped working. Do I need a...
It is possible that if you can get the motor out of there and get some WD-40 worked into the bearings you can get it running again...
turn it so the shaft is pointing up and then spray the WD-40 right on the shaft and let it run down and into the bearing...
once you get the shaft spinning more freely then place a few drops of light motor oil or sewing machine oil on the shaft and let it run into the bearing before turning the motor from the shaft up position and reinstalling...
heatman101
Sep 29, 2010 | KitchenAid KWCU265HSS Kitchen Hood
Rangemaster 256 no longer sucks air and is noisy
I have an old range master 42" vent hood and some of the electric wirer were cut & Im replacing the light switch & fan switch could you please send me the electrical digram so I can reconnect the model 256 120 v 60hz 2.5 amps
Jul 23, 2010 | Rangemaster Kitchen Hood
Range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Oct 01, 2009 | Kitchen Ranges
We are going to fit a rangemaster hood venting outside and the builder needs to know where to have the exit hole from the hood. Can you tell me how far up the hood the exit is situated
The bottom of the hood should be atleast 750mm from the top of a gas burner. Measure up from this atleast 450mm for your hole to be drilled.
Sep 29, 2009 | Rangemaster Kitchen Hood
Recirulating conversion bits.
rangemaster have a good tech help desk. you can get the number from the internet. they should be with it really. but check with them. and who installed it.
Mar 25, 2009 | Rangemaster Kitchen Hood
Want to use without outside vent
sometimes rangemaster hoods have a filter system. check with them if your model does this. nuber for tech help by them on internet.
Mar 13, 2009 | Rangemaster Kitchen Hood
Old Rangemaster Stainless Hood Parts
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 13, 2009 | Rangemaster Kitchen Hood
Rangemaster Kitchen Hood Logo
332 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
