I a Dell Dimension 4600 Series and am running Microsoft Windows XP. Everytime I try to use my DVD drive (F:), it runs for about 10-15 seconds and stops. Then the computer prompts me to "Please insert a disc into drive F:" I have no idea what to do.
  • jmaccabeus Jan 15, 2009
    Thanks - you have promptly saved me a lot of time!
    Master:
  • 416 Answers
DVD drive can not read the dvd
1. Lens is durty (DVD/CD lens cleaning disk $6 walmart)
2 Drive is faulty/damaged. Check if you can read CDs
3. DVD-Drive parameters are differnt from disks you are using
For instance it can read only DVD wit 1 to 8 speed you using dvd with speed 16. Or it reads at 2.7 you using dvd 1-8 etc. Ot it is DVD-RW you using DVD+R disckss etc.
Check the paremeters and try to use different brands DVD
Good Luck
Posted on Jan 15, 2009
    Genius:
  • 2,920 Answers
You might reinstall the drivers for the dvd player or download a different dvd player.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
  • 258 Answers
1. Click Start
2. Click Settings --> Control Panel (you may see control Panel before Settings)
3. Click System (double click)
4. Click Hardware
5. Click Device Manager
6. Find the Device you want to update by clicking the + signs
7. right click on the device and select Update Driver
8. click yes this time only --> click next
9. Click Install the software automatically --> click next
10. Now be patient while the internet and micorsoft website are searched for the driver
11. If it is found it will be installed --> click finish
Alternatively search the manufacturers website for an updated firmware
IF you post it here I will look for you
thanks HPC
  • 15,935 Answers
Your driver or firmware needs updating.
Check the manufacturer's site for newest drivers.
  • 837 Answers
Try a disc cleaner
  • 13,433 Answers
The drive is faulty, you can try a lens cleaner but its unlikely to fix it, the lens would need to be replaced, its cheaper to replace the whole drive. Or contact dell for warranty service if its under warranty.
  • Ekse Jan 15, 2009
    Did the dvd disks work before? And it supports Dvd disks?
    Just checking...
    Thanks,
    Ekse
I have a component from Maddog Multimedia I am trying to install in a Dell computer.
As long as the drive has the right conectors (IDE & Molex I suspect)
It should be fine
Oct 01, 2014 | Computers & Internet
Sure you can. XP will find it and may ask for the driver CD that comes with the Magstor.
Forgot password, Microsoft Windows xp, Media Center Edition, running on Dell Dimension forgot password, 4600 series
Forgot your Windows XP password? Don't worry about that. I have troubled the same thing before. I searched from internet and solved the problem. Now i want to share with you and hope it will really help.
Solution 1: If you have owned another available admin password, it can work. Just log on your PC->Click "Start"button->Control Panel->Add or remove user account->Select the account you want to reset->Change or Remove the password. Then the password will be reset.
Solution 2: You can use one of the password recovery software tool to reset the forgotten password. Here, i would like to introduce you one of them, which i have applied. It is really a good hand. That is Windows Password Reset . The process is following.
Step 1: Download the Windows Password Reset Deluxe from http://www.windowspasswordreset.net and burn a erasable CD
Step 2: Boot the CD into the ISO image which is provided by Windows Password Reset Deluxe
Step 3:BIOS settings
Step 4:Recover the Windows XP admin password.
It is an easy-to-use way to reset windows password.
You can have a try.
Jul 28, 2012 | Dell Dimension 4600 PC Desktop
Dimension 4600 Does Not Detect Lite-On DVD-ROM
Please take the time to remove SP3 then try to reinstall all your drivers. You should be good at that point. SP3 is known to cause some issues with drivers not working right.
If not let me know and I will try something else with you.
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Dell won't acknowledge installed DVD/RW Driver
try running this patch..
http://dell.driversdown.com/dell-drivers-downloads/Roxio-Easy-CD-Creator-5.3.4-Patch-Upgrade_23173.shtml
or try calling Dell Tech. They normally remotely access your system and run a patch and your dvd drive will show up in Sonic/Roxio
Nov 22, 2008 | Dell 16X DVD±RW Serial ATA Internal Drive...
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Jan 04, 2008 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
