Question about HP PSC 1210 All-In-One InkJet Printer
Printer no software
I recently acquired a printer from daughter and I have no software disc to load this printer, which is HP 1210 All In One. I tried via HP website and got the message access denied, How can I install this printer to our new HP 2216 Computer. Thanks, Wayne
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Did you get this "Access denied" message when you tried to install drivers? Do you have administrative privileges on your Windows account?
  • 903 Answers
Go here
and select your version of windows and then download the relelvant software. Make sure that you are logged on as an administrator or a user with administrator rights, other wise you may not be able to download or install programs, depending on what blocks you have put on for users. Generally the person who created the original user account on a new computer is an administrator and all other users created after this will have to be created as either an administrator (full rights) or a standard user which will have limited rights.
Posted on Jan 15, 2009
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Computer won't recongnize printer
The problem is with the device driver. Every piece of hardware has a corresponding software program called a device driver to let Vista/XP know it is there and what it does and how to do it. If a disc came with your printer then that is what loads the device driver. However, with USB devices you must load the driver with the USB cable unplugged from the printer. Then once the driver loads then plug in the printer...nobody knows exactly why but that is with all USB devices. So unplug and load the disc, then plug and see if it works. You may have to reboot..if that does not work let me know as they are a couple of ways to get it to working. Good luck and keep me updated. Pls rate this solution.
Apr 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP's software will not load the HP Director for my PSC 1210 all in one printer..
Are you using online or disc version. You should try each version. Make sure all updates are installed and drivers are up to date.
Mar 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 printer
The 1210 is a very old model (in computer age!) so it might not work with the EEE range, especially if you are runnning linux - you could look for linux divers in google if the EEE is running linux. If it is running windows I don't know why it wouldn't load the software as normal
Nov 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one
the fuller version is not loaded.the fuller version consists of all the facilities the printer has. load that from the 1210 installation will work. not a problem.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 printer, scanner
I presume you used the software disc which came with your printer. If so I would suggest that you go out to support and check for updated downloads for your machine. Once they are installed you should have it solved. The scanner requires extra software in addition to the printer stuff.
Aug 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1315 Scanning problems
download software for hp psc 1210 printer
Oct 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
Ben Johnson
