Question about HP Compaq Evo Notebook N600c
When you attempt to power on the compaq n600c it turns on and off repeated. the power lights come on and off, but the screen never pops up.
  • kevin m Jan 29, 2009
    i got the screen ta come up but no boot.. it goes ta start window but cant .and cant in safe mode but command prompt does come up when i press F8 or F10. help!
Try Taking The Memory Out And Then Turn it On, Then Turn It Off, And Put It Back In. Or Try Another Slot. Hope That Helps.
Posted on Feb 15, 2009
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
On start up of my compaq evo n600c the screen
Have check by a technician because the ribbon cable that runs behing the screen is loose.
Jul 16, 2009 | Computers & Internet
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Mar 26, 2009 | HP Compaq Evo Notebook N600c
All white screen on compaq n600c
When you hooked up external monitor, did you switch to it via "Fn" keys?
If it did not help, then it's GPU ot North Bridge on the board that needs service.
Mar 19, 2009 | HP Compaq Evo n600c Notebook
Delete my search history COMPAQ Evo N600c laptop
If you are using internet explorer go to tools-->internet options----->general
On this page Look for "History" and make "0" (zero) Days to keep pages in memory; also click "clear history". All the search history will be erased.
Always remember to click ----clear history--- before you exit internet explorer.
Dec 17, 2008 | HP Compaq Evo Notebook N600c
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
Replacing ram in compaq evo n600c
The little screws are Torx head screws and sized by numbers. If you have access to a basic PC tool kit there is probably a couple of torx head screw drivers or torx head screw driver bits. Be sure to remove the battery and disconnect all other power sources. Ground yourself before handling memory modules.
Apr 07, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
HP Compaq Evo Notebook N600c Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
