Question about Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 digital camera won't turn on
My digital camera won't turn on. It doesn't have any flashing lights and shutter is closed. I've used several new batteries, and no change.
  • 1 more comment
  • grrrmint Jan 19, 2009
    mine does the same thing except this red light flashes by the viewing screen on back.
  • Anonymous Mar 27, 2009
    My camera (which is almost brand new, rarely used) will not turn on - and it's not the batteries.
  • Anonymous Mar 13, 2014
    Camera will not retain user settings when changing main camera battery.
If u have cheap batterys in it it might be that try puting some duracellor some good batterys.
Posted on Jan 19, 2009
I had a problem with this as well, it would start to power on, then just shut right back down... Used some new batteries from a discount store and SURE ENOUGH, this little camera will not tolerate cheap batteries! I switched in some Duracell Copper Tops, like the above suggested, and it works just fine again...
Posted on Jul 24, 2010
Used rechargeable nimh battery ihave the the same problem, change the battery works great now
Posted on May 12, 2009
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
Blurry pictures, flash timing is off
do you use a lenz cleaner on the lenz of the camera
Dec 07, 2011 | Canon PowerShot A520 Digital Camera
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Aug 30, 2011 | Canon PowerShot A630 Digital Camera
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Nikon Coolpix L11 Digital Camera Logo
972 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
