Question about Philips 26PF5320 26 in. LCD Television
Philips 26pf3320/10 Hi Philips 26pf3320/10 lcd tv Can anyone point me in the right direction to identify the faulty circuit board /part based on the description of my fault as this will allow me to buy & replace the part. Picture illegible as very fine vertical lines down screen have color content & very faint picture in the background, The horizontal white lines come every time I turn it on then it slowly turns to a vertical rainbow where the colours move moves about to the faint picture in the background . Strange thing is after this fault arose it has returned to normal with a perfect picture on 3 occasions when I was messing about with the remote control, but that's been twice in about 100 times I tried it. I am familiar with electronics and have checked all circuit boards with magnifying glass and cannot find any blown components. I have also downloaded a service manual which shows you how to get the led to blink to sequences to id error codes but they are fast & hard to id the correct qty/sequence. Thanks Andy
  • jerm951 Apr 04, 2009
    Where did you download the service manual? I have a 32HF7543/37 that blinks red 3 times and I can't find the service manual or error code listing anywhere.
  • 3 Answers
There is a get around for this fault if you locate panel v26c look at the bottom rh corner you will find 2 test points tp11 and tp 12 if you then look on the rhs of the lcd panel actualy mounted on the side (you will have to remove the metal frame from around the screen ) you will find another panel with 2 more points tp 506 and tp507 simply solder a wire link between tp11to tp506 and another from tp12 to tp507 and that should be a permanent fix to this problem
Posted on Dec 12, 2009
  • boekenkast1 Mar 21, 2011
    Brilliant!
    I had a Philips TV (26PF3320) showing exactly the rasterlines as described.
    Taking the TV apart was not that hard.
    Note that the side board can be reached with the screen lifted a bit up in the middle.
    For soldering, use the wire-rap type lead. Small and handy!
    Soldering itself is a bit hard. Need good view and small soldering gun.
    Anyway, my TV operates now as before: brilliant!
    Thanks for the help!
    Scholar:
  • 66 Answers
Http://www.p4c.philips.com/files/3/32hf7543_37/32hf7543_37_dfu_aen.pdf
jerm951 here is the manual for your tv
Posted on May 25, 2009
SHARP TV MODEL LC-46LE830U WILL NOT TURN ON. I HAVE REPLACED THE POWER SUPPLY BOARD WITH NO HELP. IT HAS 2 BLINKING LED LIGHTS FOLLOWED BY 5 BLINKING AND REPEATING AGAIN. WHAT IS MY NEXT STEP?
It sounds that the main board fitted with your Sharp television is of Philips. Those blinks are fault indications, and you should follow the procedure of counting the number of blinks, as you do with Philips brand LCD TVs.
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Sharp Televison & Video
Sharp LC-70LE650U blinking code 2 slow 5 fast
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Some models of Sharp TV uses Philips main board. If your TV has such a board fitted, you should follow the blink count procedure for Philips. From your description itself, I do understand that your TV is fitted with such a board. The blinking code procedure seems so.
Nov 05, 2016 | Sharp AQUOS LC-70LE650U 70" LED TV...
42 Philips tv won't turn on just blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 10, 2015 | Philips 40PFL4706 40 LED-LCD TV - 16:9 -...
Philips 42PFL7403D/F7 LCD TV. red light blinking where the on/off light is. TV will not turn on.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Philips Televison & Video
It turns on shows the philips symbol the shuts off
There should be any short circuited component/s inside the circuit board. If the TV turns OFF after turns ON, it should really show blinking codes, that is, its standby/power LED will blink to certain times. These are called blinking codes, and you can get an idea about the faulty circuit stage inside the TV by these blinking codes. But, to Philips TVs, these blinks cannot be directly counted. There is a special way to count it, which in turn give you either a single digit, or two digit fault codes. You should find out the faulty circuit stage by this fault code.
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 31, 2013 | Philips 32PFL3505D 32 in LCD TV
05 42pfl766d philps
It will be best to contact the authorized dealer for Philips.
Jul 23, 2013 | Philips 42 in. LCD TV
Philips 32" tv will not turn on flashing three
hi,
You have to check the power supply of you tv for any voltage missing. also check the back light inverter board for any short circuit in it. Inverter transformers in the back light controlling board can become faulty.Three blink indicate the power supply have some problem. First of all replace all the electrolytic capacitors in the power supply board. If filter capacitors in the power supply is bad then this problem can occur.
ok
Jun 09, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
HI FEW DAYS AGO I GOT VOLTAGE PROBLEM. AFTER THAT MY LCD Philips LCD TV 32PFL5403D GOT SOME TROUBLE. IT STARTS BUT COULDN'T SHOW ANY PIC LIKE DVD, COMPUTER, SATELLITE RECEIVER & CABLE ALSO. WHEN I...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Jul 25, 2017 | Philips 32PFL5403D/27 32 in. LCD TV
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Jan 19, 2010 | Philips Televison & Video
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Jan 20, 2009 | Televison & Video
Philips 26PF5320 26 in. LCD Television Logo
1,725 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
