Question about Syntax SV266A SKA KT266A Motherboard
Bios hi can anyone tell me what i do to upgrade my bios and where would i find it upgraded bios that is. cheers dessy
  • 1 more comment
  • michael desborough Jun 17, 2007
    thank you
    hi sorry to trouble you again ive looked at the site you pointed me to but it looks a bit to simple dont i have to get into the bios fisrt and change anything
    dessy
  • michael desborough Jun 18, 2007
    thank you
    President:
  • 2,961 Answers
As you will probably know Syntax boards are no longer, but are more or less the same as PC Chips boards, but sv2661 is rather old and is not supported on the pc chips site so you can download the last bios update from the link below and instructions on how it's done. http://www.computer-help.net/Syntax-SystemBoard-SV266a-Bios-Upgrade.htm
Posted on Jun 17, 2007
  • andrew pester
    andrew pester Jun 17, 2007
    please rate the solution, as we need to know if usefull or not, thx
  • andrew pester
    no, the floppy bios.exe programme when you start the system up with the floppy does it fo you, the bios is erased an rewritten
SOURCE:
I want bios update my IBM Lenovo 7298 pc
Hi
If you go to the page below there are many options for installing a BIOS update.
Desktops and all in ones ThinkCentre Series desktops ThinkCentre M58e...
There are also various utilities to help you upgrade the BIOS, including one for upgrading from within Windows. You should make sure that you have a full backup of your data and programmes before you start. Please make sure that the version here is an upgrade compared with your current version and that you read the instructions very carefully and are comfortable with them as incorrectly upgrading, or interrupting the upgrade can lead to your machine refusing to boot at all from anything. Please be careful.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Lenovo ThinkCentre M58e 7298 Core Duo...
My acer beeps twice on start up and then shuts down about ten times before it will start
Hi, well firstly let me tell you that these "beeps" which you hear is in fact "codes" that tells us about the status of the PC. There are different types of beeps depending o the BIOS manufacturer such as Phoenix,Award etc
In your case the two beeps is related to RAM memory error. The computer is waiting for user input. Probably you upgraded your RAM recently & the PC is waiting for your input in BIOS & is shutting down automatically. Power on your computer, hold "F2" key to enter BIOS & "Exit saving changes".
Well, dear your problem will surely be solved! Cheer up....
Please send us your valuable feedback & vote so that we know our strength or weaknesses.
Feb 14, 2010 | Acer Extensa 5420-5687 Notebook
About Bios Upgrade
1st update your ROM BIOS
here a site may help you
http://www.uniflash.org/
http://wims.rainbow-software.org/
or
in this link it has intruction how to flash it and all you need its there
http://support.octek.com.au/Products/MainBoards/BIOS/bios_0014.htm
Hope it work for you ^_^
Jun 09, 2009 | Intel Motherboard
Bios needs upgrading
Please go to www.biosman.com
you will get all you need.
May 05, 2009 | FIC VI 13L Motherboard
Gigabyte GA-60X Memory upgrade.
Hey syconus, Matt here- It will unfortuatly still only take the 512mb because it is not compatible with the new memory. Sorry:|.
Dec 31, 2008 | Gigabyte GA-6OX Motherboard
How bios upgrade
if you go to the website for your board they will have the lastest bios upgrade and flash utility. also you will find a text file that tells you what bug fixes the newer bios cures.
be that as it may.... i just don't recommend a bios upgrade if everything is working as you can cause the computer to fail if you flash the incorrect bios etc.
Robert
Sep 08, 2008 | Computers & Internet
Can i upgrade the bios
If you upgrade it and everything goes ok the warranty should be ok.
Some people have problems upgrading bios files and render the motherboard unusable. If that happens you may have a problem with warranty. But only if you tell them you did it.
Jul 17, 2008 | Intel D101GGCL: uATX Socket775 FSB800...
P35-611 Memory upgrade question
hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
this may just be a read problem and it needs to learn that you have a 2 gig mem
if not let me know and we can try another way for you ok
hope this helps ok
all the best
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Cpu upgrade for zv6000
Most of the newer processors use a different socket.
The Socket 939 chips go up to an Athlon 64 X2 4400+.
However: keep in mind that your computer's bios may not be setup to use newer CPU's. The only way to tell is to check compaq's web site for updates or just to buy a CPU and try it.
Dec 03, 2007 | IBM ThinkPad T22 2647 Notebook
Syntax SV266A SKA KT266A Motherboard Logo
249 people viewed this question
Top Syntax Computers & Internet Experts
Alun Cox
k24674
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
