Question about Lifetime 71729 In Ground Basketball Hoop
Water inside basketball support
I am afraid that the water inside the basketball support tank will freeze tonight when the temperature drops down to the predicted 9 degrees tonight. Is it OK if I put antifreeze in the water inside the basketball support tank?
  • 15,935 Answers
No, the automotive antifreeze is acidic, and will eat through the thin plastic.
A better option is RV Antifreeze - it is PINK and available at RV centers. You will need at LEAST 2 gallons to have the correct mixture.
Better option - empty it out, and fill with sand.
:D
Posted on Jan 15, 2009
Water tank freezes
I guess you've got it way too cold down there!
It's always a great idea to use an external Temperature indicator to
keep the Temp in limits.
Helps save power too and keep the electric bills down.
I set my fridge at 3-4 Deg
Freezer at 2 degrees below freezing
Digital Thermometer for Fridge or Freezer Keyrings Weather Forecasting...
Sep 18, 2015 | Refrigerators
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Water Dispenser Temperature Control/switch-off
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Nov 26, 2013 | Samsung RF4287HA
Tank sweats profusly
Sweating tank can cause moisture problems inside bathroom.
Sweating is caused when incoming water temperature is hotter or colder than air temperature inside bathroom.
You can verify this by not flushing tank for several hours and notice that sweating stops once water inside tank warms or cools to same temperature inside bathroom.
Problem can also be cause when there is not enough ventilation inside bathroom and water on tank does not evaporate.
To solve problem:
1) Increase bathroom ventilation and add dehumidifier or fan so condensation drys.
2) Insulate interior of tank. Empty water and let tank dry. Tape off moveable parts. Use can of spray foam and insulate inside of tank. Let foam dry and cut away excess foam.
3) Add tempering tank or staging tank inside room to pre-heat/cool water before it enters tank
http://waterheatertimer.org/Tempering-tank.html
Mar 22, 2011 | Eljer & Titan Elongated Toilet Bowl
My car BMW 318i 2000 model was parked for about 1.5 years without driving. the water pipes are bursting. first it was the plastic pipe on the engine and after replacing, the water tank on the side of the...
Is the water tank the windshield washer fluid or the radiator overflow tank??
If it is the washer fluid tank, fill it with "below 32F" type fluid. If it is the radiator over flow tank, it would appear to me that the radiator fluid is too watered down or weak and is not freeze resistant. The radiator fluid should be 50/50 mix of Prestone or other make of radiator fluid and water. This is to save your engine and radiator from bursting. Ice takes up move volume that water (this is why Ice floats on water). Inside of a pipe, radiator or engine block, this can be devisating. You could crack your radiator or engine block. Hopefully who ever serviced your car last used the correct fluid. You might want to get this checked before more damage happens to your car.
Hope this helps.
Jan 01, 2011 | BMW 318 Cars & Trucks
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
I have a GE side by side refrigerator that in the past has had issues with the water tank freezing up. Everytime this has happened I have removed the bins and used a hairdryer to dethaw the tank. The water...
I believe you are having a combination of problems. Your air damper with fan is malfunctioning and causing freezing inside your fresh food section. The part number is WR49X10091 and there is a better replacement for that now.Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator. As for the water tank epoxy does not work well with plastic so I would replace the tank to prevent having to go back later and do it again. I will assist you through this if you like, Thanks, Sea Breeze
Dec 28, 2009 | GE GSS25KGSBB 36" 25.4 Cu. Ft....
My gas water heater sometimes sounds like its perculating. Is this a problem?
It can be if it keeps boiling the water. Your tank will have a pressure relief valve with a copper pipe dropping down near the floor...is there signs of water coming out of the pipe? Be certain it is working by testing it...lift the lever in the center of the relief (Place a bucket under the pipe first to catch the water that will flow out). Over time these valves can rust up and not work.
In the worst case, boiling the water causes steam build up in the tank which is under pressure. Enough steam can cause the tank to rupture and that is a bad thing.
I am not certain but you probably need a new temperature probe if the tank is over heating the water inside.
Dec 16, 2009 | Water Heaters
My ps3 freezes in the middle of games and movies. And sometimes it doesn't even play the movie.
Hey guys i had this same problem 2 times the second time being tonight and i fixed it both times! I don't usually post on forums but im just trying to help out here i know it can be really frustrating when this happens. Anyways what i did to fix the problem is lift the ps3 a couple inches off the ground and gently drop it so the dust or w.e it is in the ps3 settles n fixes. The second time this happened (tonight) i tried dropping it again and it didn't work, it really got me mad, but then i tried dropping it again this time upside down and after 1 drop it worked. anyways hope this helps :)
If i am helpful to you, please rate me.
Aug 11, 2009 | Sony PlayStation® 3 (80GB) Console
Lifetime 71729 In Ground Basketball Hoop Logo
511 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
