Question about Toshiba 32AF43 32" TV
Remote problems The TV remote does not work, even with fresh batteries; the "multi-brand remote" supplied by the Cable company does not work either. So I rearrange my room, and the TV is without power for a few hours; when it gets plugged in, the remote works again, for a day or so, then stops. SO, if I REALLY want to use the remote, I have to unplug the TV for an hour or two, and the remote will work, for a little while. What on earth is going on? (The cable remote works the same way, so it has to be with the TV; i.e. if I unplug the TV, then when it gets plugged back in, either the tTV or CATV remote will work...for a while.) Thanks
    Genius:
  • 1,074 Answers
It is possible that your tv IR circuit is the problem could be that a cap needs to replace.as posted by you saying that when you plug in the tv the remote works, that means voltage charge up the cap and the tv works with the remtoe but as soon as you switch off the tv the cap discharge the stored voltage so you will have to plug in the tv for the cap to charge,and in order for the remote to activate the tv.that cap can be found just near the IR diode.good luck.
Posted on Jun 18, 2007
SOURCE:
Remote control not working even though I have inserted new batteries
If known-good batteries were installed, the remote control may be defective. Check for corroded battery contacts.
Dec 20, 2017 | Televison & Video
Samsung led tv 5003 remote channel selector not working, must use cable company remote. Volume only works on samsung remote.
The cable company remote will have under settings a program code function for the remote. Setting the Samsung code will enable the cable remote to adjust the volume. Many TVs have more than one code. You may need to try several to get the right one.
the attached images are examples of this process. Your remote supplied from the cable provider will have its own unique process. Consult the info supplied with the remote. Access the help feature available with some cable services. Your cable provider may have the help function available on their Website.
Hope this helps?
Sep 28, 2016 | Samsung Televison & Video
Sharp aquos remote not working
Check the remote controls for its infra-red emission. Check them with fresh new batteries. If there is no infrared rays come out from its front window/LED; the remote control is faulty. If the remote controls are found OK, and the TV do not respond to it, the infrared sensor inside the TV is faulty; should be replaced.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
If you have to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Jul 18, 2016 | Sharp Aquos Televison & Video
Code for sony tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily......
May 04, 2016 | Conect It RM500 Multi-Brand Universal...
Remote won't run tv.
Buy a new remote. Or a Universal remote which has you TV on it's code listing
Jun 05, 2015 | Zenith Televison & Video
Remote not working for 19" bush tv
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get some details, check the site linked here. Pull up older posts. If the remote control is found faulty and, you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 08, 2013 | Televison & Video
I need tv codes for a sharp tv for the universal conect it Rm400 Remote
0038,0019,0058,0022,0019,0000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 08, 2013 | Conect It RM400 Multi-Brand Universal...
My battery in my remote were taken out and when this was done I was unable to use the remote to control the cable/T.V. when the batteries were replaced. I set up my remote to turn the T.V. on and off, but...
If the remote control is not broken, the batteries are almost out of power supply. Especially with remote controls that perform multifunction capabilities like with universal controllers. Replace the remote control with new powered batteries. Important notes include being weary of the capacity battery power supply because some brands are incabable of providing supply to remote controllers. For example, unless the remote control requests specific brand battery power supplies, energiser or duracell bateries would power up any device.
Jan 08, 2011 | Televison & Video
Gfm tv universal remote code
Use the code for the sylvania tv. It worked for me!
Apr 30, 2008 | Televison & Video
QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Dec 31, 2007 | Olevia LT42HVi 42 in. LCD Television
Toshiba 32AF43 32" TV Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
