Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 model 110
How does one remove the push/pull cycle knob. I need to replace the plastic piece under the knob.
  • cgh66086 Jan 16, 2009
    110.24832200
    I thank you but this suggestion did not work.
  • cgh66086 Jan 18, 2009
    Thank you very much. I now think that I have more of a problem than I first thought. I do unplug the washer and pull the cycle control knob out and turn it counter-clockwise and it just turns or push the cck in and it just turns. So now I guess I need instructions on how to get the front panel open, I believe something is broken in the cycle control piece itself.
  • 5,911 Answers
If you are talking about the Cycle Selection knob, turn the washer to an OFF position, or unplug. I can't remember if you need to pull the knob out or leave pushed in, but the knob will come off by turning it counter-clockwise. After unscrewing it and removing, the plastic dial under the center knob will simply pull off. I hope this helps you. If you need further assistance, please let me know.
Posted on Jan 16, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 16, 2009
    Are you sure? I just confirmed the drawings with the correct model number that you just now posted and the the timer control knob for your washer unscrews in a counter-clockwise direction to be removed. The rest of the control knobs on the front panel simply pull off. Perhaps you could send a photo or describe what you have done rather than leaving an adverse rating. I gave the best assessment I could with the information you provided.
I have a Kenmore 80 series model 110 24832200 washer which stopped working mid-cycle. It won't drain and when we attempt to change the cycle or restart it the machine only buzzes. Thoughts?
These machines are direct drive and have a plastic drive coupler which fails. Unplug machine and pull away from wall careful of water and drain connections. Tilt machine back for access to bottom look for the drive coupler between the motor and transmission. It is white plastic on each end with a black rubber piece sandwiched in between. You should be able to tell if it is broken by just moving it by hand. Replace this part and you should be back in business.
Apr 18, 2010 | Kenmore 24902 Top Load Washer
Kenmore washer Model # 110.26852504 Cycle control knob?
You gotta pull out a rod behind the timer and that releases the knob.351bd46.jpg The rod when pushed into the timer spreads the shaft and holds it on there. To get to the innards you gotta flip up the controls. I have a cool video that shows how
Mar 12, 2010 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series wont run at all
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 29, 2009 | Kenmore 23822 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Agitates but does not spin Kenmore 5 year old Model 110
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 03, 2009 | Kenmore Washing Machines
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
403 people viewed this question
Sal De
fordexpert
Robert Rankin
