Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Nut problem Hi - My fan stopped running smoothly the other night and the problem seems to be with the fan blade nut. The blades are not tightly affixed to the motor because the fan blade nut will not fully tighten/fasten. I've been trying to get the nut off to re-do it, but it won't come off. Any suggestions? Thanks!
  • Jennifer Wilson Jun 17, 2007
    I tried that, but to no avail. It won't move either way - just spins in the same place.
    Scholar:
  • 121 Answers
This might be a long shot, but have you tried turning the nut the opposite way? The nut will probably have to be turned the opposite way of the rotation of the blades. This might be the "wrong way". Some nuts are opposite to keep things from comming off. Like the nuts on the right side of my remote car to keep the wheels from falling off.
Posted on Jun 17, 2007
SOURCE:
The fan is wobbeling
get a new blade perhaps
Mar 15, 2015 | Dryers
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Craftsman edger model 358.796480 blade not cutting. Am I doing something wrong? Seems like looks OK but still not cutting.
Assuming the obvious that the motor is turning, the only thing that would keep it from cutting is that the nut holding the blade is not tight enough or the sping washer between the nut and the blade is missing or on backwards. The correct orientation of the spring washer is so the inside surface around the hole contacts the nut, and the outside circumfrance of the washer contacts the blade. P.S. the nut is tightened very tight.
May 18, 2014 | Garden
I have a used version of this saw, bought it yesterday. It turns on fine, but I need to change the blade. It seems there is a quick release circular spinner that allows for you to do so, but I cannot...
-Remove the blade cover.
-Loose the nut that hold the blade. Loose the blade tension.
-Remove the old chain then put new one in. Tight the tension to
to good or until the chain still turn smooth. (Not over tight)
Tight the locking nut.
-Put the cover back.
You're done
Good luck end enjoy
Mai
Dec 06, 2017 | Ryobi RCS3535CA 14-inch 35cc Petrol...
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
How do I pull out the upper radiator hose on a 2006 X5 3.0?
grab it real tight. wiggle and voila...it pops out.
remove fan blade nut. left handed 22mm nut also 1.25 open end american will get it.
must remove fan shroud with blade.
upper and lower hoses, airbox and sensor wires, coolant expansion tank, and anything else you can see in the way. must use a grabber tool when removing fan blade nut.
Feb 01, 2010 | 2001 BMW 5 Series
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Plz rate my solution.
Thabks.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
199 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
