Question about Peavey 32fx USB 32 Channel Mixer
PV6 clip lights stay on
This problem is concerning a Peavey PV6 mixing console. When I turn on the power, all the clip lights come on and remain on. The user manual says that the lights are there to indicate when something is too hot but, they are all on even when no devices are connected to it. Plus, no sound is going through the board at all. I have tried every connection with several different devices and no sound is coming through. Is there a blown fuse or something that might be causing this problem? Any help would be appreciated.
  • Frank Allik
    Frank Allik May 11, 2010
    Jan 15, 2009....thats awhile ago....have you takin everything out of line...unplugged everything except the power cord???
    Problem Solver:
  • 5 Answers
You've lost one of the power supply rails. It needs to be repaired or replaced.
Posted on Aug 02, 2009
What is the power supply number for peavey pv 6
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Mar 26, 2014 | Peavey PV6 Mixer
I have been given a peavey pv8 mixer without the power supply, I have used a different power supply with the same voltage, my problem is when it's turned on the clip lights are glowing on all channels and...
Kinda hard to tell you exactly what the problem is. Your current power supply may not be able to give you the amperage you need even though the voltage is the same. You can get the correct power supply on Ebay.
Peavey 16 5 Volt II Power Supply 03013830 Mixer PV6 PV8 PV14 PV 6 8 14 16...
Dec 20, 2017 | Music
Problems
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
Jul 03, 2013 | Peavey PV6 Mixer
Clip is on as soon as I turn power on.
Sometimes this may be a result of a subsonic or supersonic signal, if it still does it with nothing at all plugged in and the FX turned right down there is a fault with your mixer.
Apr 16, 2013 | Peavey PV6 Mixer
Manual for Peavey PV6 6 channel mixer
Aug 05, 2012 | Peavey Electronics Peavey Pv6 6-channel...
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
All the channels shows the Clip red light on the Peavey PV6 6 channel mixer and I´m unable to use the device ...Whats is the solution??
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
Oct 26, 2010 | Peavey 32fx USB 32 Channel Mixer
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
The DDT light on one channel stays on,but I can't find a reason why? What can I do?
Disconnect the speaker wiring and speaker on the bad channel. Turn the level control(s) all the way counterclockwise and turn the amp on. If your DDT (limiting) light remains lit, it's time for a visit to your nearest certified Peavey service center....G.
Feb 05, 2010 | Peavey Pv 2600 Power Amplifier
My pv6 mixers red clip lights remain on
FIRST check that your power adapter is 16 VAC at 1 AMP and that it is the original unit.
The clip lights monitor levels at several points. If you cranked the EQ's for maximum, say bass, that MAY cause them to illuminate.
As a test, set all EQ's at mid point. Remove ALL input cables. Are the lights still on?
It is possible that you can have a ground loop that is putting signals in that causes clipping. Another source is if you have a microphone that may be FEEDBACKING at supersonic frequency that you can't hear... that is why we disconnect all the inputs as a test.
Finding schematics so one can repair these devices can be a problem. If ALL the clip lights ar on, then it is probably the reference level source for the clip level threshold... however finding a schematic would be necessary and while part cost would be probably under a dollar, the labor and time to find the schematic would be unknown.
Aug 18, 2009 | Peavey 32fx USB 32 Channel Mixer
Peavey 32fx USB 32 Channel Mixer Logo
759 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
