Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Problem with water cycling
Dishwasher cycles but no water cycles with it...water valve is open
  • rngbar Jan 15, 2009
    maytag jet clean MDB4050AWW
    President:
  • 1,214 Answers
You say the water valve is open, are you referring to the supply water valve, or the water valve inside the dishwasher?
If the supply valve is open, then chances are that the electric water valve inside the dishwasher is bad, or the dishwasher control is bad.
Usually, the water line connects right at the water valve, underneath the dishwasher.
Reply with the make and model number of the DW and I can give further instruction if you or someone you know is good with a multimeter and reading schematics or wiring diagrams.
Posted on Jan 15, 2009
  • Mark Egan Jan 16, 2009
    Yes, I just installed one of these for my daughter and son-in-law.
    The valve is located on the bottom left or left side (can't remember for sure.).
    There is also a fill float on the bottom left of the wash drum, which actuates a switch on the bottom of the unit. Check that the float has not hung up, in an upward position. If it's not hung, you will need to determine if there is trash in the water valve inlet screen, if the coil on the valve is bad, or if the fill switch is bad.
    Make sure that there is water at the water valve for sure.
Took out the dishwasher because we changed the floor covering. After the new floor covering was laid I put the dishwasher back in to where it goes. Hooked up the hot water and drain and plugged into power...
most dishwashers are fitted with pressure switch and overtemp features.. shortage of water should not have damaged machine in any way.. sound like you may have faulty solenoid which allows water electronicly in to the machine.... thus causing safety device to freeze timer
Feb 28, 2011 | Imperial IFS40 Deep Fryer
Water does not enter dishwasher during wash cycle
Make sure the under-sink valve is turned on. Then suspect the water solenoid valve under the front may have an open coil or stuck shut valve.
Dec 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Power point dishwasher - not washing dishes
Jun 18, 2009 | Dishwashers
Water won't fill, it run through the cycles though
Jun 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Water into washer
Jun 05, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Dec 16, 2008 | Maytag MDB9600A Jetclean II Built-in...
Water Sitting In Dishwasher after Completion of Cycle
An obstruction in the water-inlet valve may mean that it's no longer able to shut off properly. You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! In case cleaning will not help, you should replace the valve. Good luck !
Sep 09, 2007 | Bosch SHU5315UC Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
165 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
