Question about Aiwa NSX-AJ50 Shelf System
Aiwa NSX-V70 Cassette deck Belt?
Does anyone know where to buy the replacement belts for Aiwa Model NSX-V70( which I think it is now Sony) Cassette Deck?
Any online parts suppliers or shops that have them would be great help.
    Problem Solver:
  • 7 Answers
U can get from website many type belts for sepcaly aiwa nsx seriess,all total cost 25 euro
Posted on Oct 10, 2012
  • 135 Answers
Aiwa model ad3100u
Marrs Communications is all you need to know about getting the right belts but putting them in is another subject.
Aug 22, 2014 | Sony CASSETTE DECK Single Dual Cassette...
Only one spindle turns on cassette player
It is probably a loose or broken belt. I do not know the unit so this is just a starting point.
Aug 10, 2014 | Aiwa Audio Players & Recorders
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
I have a AIWA brand music system model NSX-V70. It has Tape--Tuner--Video/Aux--CD facility. Problem: 1) CD changer is not operating, it is locked, not opening as a result can not play any CD or DVD. It is...
It is possible that your Cd and teh tape section has a belt problem. The loading belts of the cd and the tape transport is worrn out and results in non action. Since there is no drive the cd mechanism nor your tape mechanism will work. If you have a help around ask them to open the top cover, remove the tray and look inside for the loading motor of the CD. replace and keep the Cd section out. by removing the connecting corrds very carrefully. ZThe tape deck mechanism is within and you will see the belt worn out. The front panel and the deck assembly can be taken out and the belts can be replaced. Attempt to do the job only if you are familiar with electronics other wise get help from a good reputed service shop to replace the motors. However this is not a expensive work but must involve great caution not to damage any parts with inexperience. I hope you understand and find this helpful. Pune is a great place and if you look around find a good sincere technician to help . Good day
Mar 24, 2010 | Aiwa Audio Players & Recorders
I have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Feb 26, 2010 | Aiwa Audio Players & Recorders
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Feb 23, 2010 | Aiwa Audio Players & Recorders
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
Aiwa NSX-V70 Cassette Deck Belt Replacement
try I think you can get what you need there!
Please rate my response!Thanks!
Jan 15, 2009 | Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
Aiwa NSX-AJ50 Shelf System Logo
877 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
