Question about Bosch SHU5316UC Dishwasher
Vented vs. non-vented dispenser unit
I ordered a replacement dispenser assembly unit online. The picture looked identical to the unit I needed to replace. However, when it arrived I realized that it was "vented", i.e. it has an opening into the inside of the door panel. The unit I'm replacing does not have this vent. The place I got the unit from does not offer a non-vented unit. Questions: What's the purpose of this vent? Is it ok to leave this vent into the door panel? Is there a way to cap it?
  • 27 Answers
If you cannot get a non-vented unit, just buy the vent fitting that fits onto the dispenser unit....it runs accross the door panel and down the door to the gutter in the bottom of the door. There should be no problem using the unit "as-is", but if you see small amounts of water dripping from below the outer door panel, get the vent tube. It should be inexpensive. Oshie
Posted on Jun 26, 2007
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Does the battery need to be vented on a Jaguar
The new battery is most likely a gel type - they are zero maintenance, non-vented batteries. They are also becoming much more common than the older lead-acid style.
Hope this helps, Sherwin
Jan 18, 2010 | 2001 Jaguar S-Type
I just bought a used Rinnai 1004f propane monitor and it came without the vent to outside. How can I get a vent? (Maybe kit) The wall is 16 inches thick. Jim Marstaller Naples, Maine
is this a vented or non vented unit? have you checked the rinnai distributorship? call Adirondack Hardware in Keeseville NY. They have parts for Toyostove, Monitors and Rinnai heaters. Their staff are very well versed in all kero and propane heaters.
Oct 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Need to know whats better for my car. a vented gas cap or a non vented gas cap?
replace it with the same type of gas cap that was on it originally. if you aren't sure call a dealer they should be able to provide the information.
Sep 02, 2009 | 2001 Nissan Maxima
Hello, our handle broke off. who can we get to fix it?
record your model number off of the unit and go to www.searspartsdirect.com where you can order the part needed and install it yourself. Otherwise, if you'd feel more comfortable with certified repair, call A&E Factory Service, or www.aefactoryservice.com.
Jun 25, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Which gas cap vented or non-vented?
The cap is supposed to be non vwnted for the vapor recovery to function properly. good luc.
Jun 13, 2009 | 2007 Nissan Titan LE
Does the Frigidaire FAC 126P1A need to be vented?
It must be installed in a window openeing or through the wall.
A load bearing wall is no problem.
Cutout the opening larger than the unit and install a header in the wall cutout.
Mar 12, 2009 | Frigidaire FAC126P1 wall/window Air...
Broke the handle and need to get it replaced
this is joyce,
How bad did you break the handle can it be glued back or will it have to be replaced, some times the entire door assembley has to be replaced , go to splendide.com and download your document on this paticular unit and look to see if it has a breakdown on the door handle unit and then you may be able to just order the handle.
thanks,
joyce
Feb 07, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Bosch SHU5316UC Dishwasher Logo
233 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
