Question about Canon DR 2080C Path-Through Scanner
CANON 2080c scanner not scanning bottom quarter inch of page
Canon 2080c scanner: Customer scans docs with print near the bottom of the page, and when you look at the image on the monitor, approx lower quarter inch of page is blank. Scanner has new feed/sep rollers, Any suggestions? Thanks.
  • 490 Answers
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Posted on Feb 04, 2009
I have a Canon DR-2080C. Black line appears on the front page but when a scan as duplex it is not on the back page. How do I fix?
The top module has dirt stuck and bottom module is clean. Please clean the scan module with Isopropyl alcohol. For emergencies take a drop of cologne on a piece of cloth and wipe the area that is dirty.
S. Mohan
Mar 09, 2012 | Canon DR 2080C Path-Through Scanner
Canon Scanner DR-2580-C (Black lines around border of document)
It seems that your scanner is conflicting with previously installed software. It is impossible to say whether it is Canon or Adobe. Reinstalling Acrobat or updating it may work as trying a different folder like Desktop instead of My Documents. One or more drivers are at fault. What system are you running? 2000, XP, Linux? Update your video rendering software too. Let me know so that I can help solve this issue. Just try as mentioned first.
Nov 06, 2007 | Canon DR-2580C Path-Through Scanner
Line appearing on document
Clean the glass thoroughly with a damp cloth.
S. Mohan
Sep 30, 2009 | Canon DR 2080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
Aug 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Feeding problem
There are quite a few optical paper sensors in any scanner. If one of them is blocked by a shred of paper, the scanners 'assumes' the paper is available and starts scanning. Try to blow air and clean the scanner. Take care not to damage the sensors. S. Mohan, India
Dec 24, 2008 | Canon DR 2080C Path-Through Scanner
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Missing the disc
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here:
Oct 02, 2008 | Canon DR 2080C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
228 people viewed this question
old marine
old marine
