Question about Burton R.e.d. Hi-fi Stigma Xl Snowboard Helmet 2008
How do you attach goggles to a Burton RED helmet?? How do you open the ******** the back of the helmet?? I'm affraid to just pull really hard and snap it off.
    Problem Solver:
  • 14 Answers
You wont snap it off just pull.
Posted on Jul 10, 2009
  • 39 Answers
If the back of the helemt has a bungee strap you have to pull really hard to get it out. Its a pain. if its just a clip slide it under (you probably know that but hey some people...). Hope this helps you!!!
Posted on Mar 29, 2009
How do I change the battery in my welding hood cause sometimes the lens will darkin and sometimes it won't? Also the lens will not adjust the darkness when I change the shade
This Helmet is solar powered leave it on your dash to charge it a few hours will work just fine there is no battery the solar cell holds the power Try getting a full charge on it then see if the darkness will adjust .
Nov 23, 2010 | Uvex Optrel Satellite Welding Helmet #...
Helmet quit darkening. It is like the grinding shade only. It has been acting up. Some time if you put it in the sun for a 5 min it will work.
If it is still under warranty then send it back, a welding helmet is something I really really don't want to try and 'fix'. Just replace it.
May 05, 2010 | Uvex Optrel Satellite Welding Helmet #...
Boy just got a burton hero board, put on his danny kass bindings. The EST system for binding attachment seems to stink. Only two screw attachment, they immediately loosen up. How to attach tighter?
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
Mar 06, 2010 | Burton Winter Sports
Is it true you don't wear a toque if you wear a snowboarding helmet?
I have a helmet and I don't need a hat under it. The helmet is quite warm. They also usually have vents to open for those warmer days.
Dec 01, 2008 | Dual Electronics Lightweight Polyurethane...
Do snowboard helmets work with earphones?
These in-ear monitors would probably work really well with a helmet - there is just a couple of things to think about. This type of earphone really seals the ear and blocks out other sounds which is good for critical listening but you might not be able to hear the noob sliding into your back as he screams down the hill. Also is the problem with how hard snowboarding is on everything when you crash - one good yard sale and those $100+ earphones (or the wires going to them) could easily be crunched. I would say spend the same amount of money on a helmet with speakers built in and leave the volume at a moderate level and avoid the possible problems. Good Luck
Kids helmet
For kids, it is important not to purchase a helmet to big for their head. A helmet that is too loose or large is not going to be safe and can do more harm in the long run. Kids heads grow slowly compared to the rest of their bodies so make sure you order a helmet that fits. The only time you may want to bump up a size is if the head is right in-between sizes. Then you may op to select a larger size.
How to fit a snowboard helmet?
"Getting the right fit is the most important factor to consider when buying a Snowboarding Helmet: 1. Measuring Tape. Your helmet size is determined by the circumference of your head. Wrap a measuring tape around your head to get your helmet size. 2. Align the front of the helmet above your eyebrows and hold both straps until the helmet fits well. 3. Make sure there are no unwanted gaps between the helmet lining and your head. The back of the helmet should not touch the back of your neck. 4. The helmet should fit snug and nicely. 5. Try one of your favorite pairs of Snowboard Goggles and make sure they fit properly on your helmet. Please note that the producers of helmets all have different ideas on the shape of a human head. Although the size might be right, the shape of the helmet might be different from the shape of your head."
Snowboard helmet safety rating
"Snowboarding and Skiing Helmet Safety Standards Snowboarding Helmets should have a CE, ASTM or Snell RS-98 certification. ASTM standards have been determined by a series of tests on helmet models, including testing the strength of a helmet's retention system under simulated hot, cold, and wet conditions. "
Recomanded protective gear
always wear an helmet while working with any kind of demolition or heavy tool. Safety first!
Aug 27, 2008 | Makita HM1810 Factory-Reconditioned 70 lb....
Burton R.e.d. Hi-fi Stigma Xl Snowboard Helmet  2008 Logo
308 people viewed this question
Top Burton Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
