I tried taking the battery out and unplugging power cord and held the power button for 30-60 seconds and that didnt work.
SOURCE: Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
SOURCE: Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
SOURCE: Toshiba Satellite a60 password help?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
====1st Method====
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
====2nd Method====
1. Reboot your machine.
2. Press F8 before the Windows boot screen appears.
o Do not press F5 as used on the NT/9x series of Windows.
3. You will be be prompted with a boot options menu.
4. Select the Start Windows in Safe Mode option.
5. Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
6. Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
7. Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
o The Safe Mode Welcome screen might display some of the other users on your system.
8. Login as the admin.
9. Press Yes at the prompt asking if you would like to continue using Safe Mode.
10. Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
11. Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
12. Login as the user for which you set the password.
====3rd Method====
Windows XP and further versions also provide another method to recover forgotten password by using “Reset Disk”. If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
http://support.microsoft.com/kb/305478
====4th method====
Comparatively, using windows password Recovery Tool utility is a reliable and convenient method for solving the password problem. Normally, the program can easily reset the password to “Blank” with no -reformatting or installation. Do all the job for you automatically. Unfortunately, it is not safe to use some free recovery tool to recover windows password. So here is the recommend recovery tool:windows password Recovery Tool 3.0 .
Offical site: http://www.windowspasswordsrecovery.com
you could see the recommendation of articlesbase.
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html
====5th method====
If it doesn't work above ,I hope that you have some hacker friends.
====Reference resource====:
http://windowspassword.blog.com/
http://www.wikihow.com/Recover-Windows-Administrator-Password-if-You-Forgot-It
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html#
http://www.instructables.com/id/How-to-Reset-Recover-Forgotten-Windows-NT-2000-2001/
Testimonial: ":) you're awesome thank you"
SOURCE: My Toshiba Satellite L505DS6947 power
HI walkerkenn
try connect your laptop to external monitor.
if you windows can boot normaly, tht mean your screen display got problems
but if still can't boot that mean you must do the troubleshooting process with one by one on your laptop hardware such as ram, hdd or mainboard ( this work need you prepared more computer skill and compenent to make the troubleshooting process )
regarda
SOURCE: hello my toshiba satellite c650
I've just had this same problem with my cousins computer. This solution seems to have worked.
Unplug the power cord from the laptop and remove the battery.
Press and hold the power button for 30-60 seconds
Plug the power cord back in and then try to boot.
I hope this helps.
