Question about Philips PP 405 Printer
Cover open i have printer second hand and in the display apear '' cover open''. i don't know where is the contact of cover
    Genius:
  • 2,985 Answers
Look up www.fixyourownprinter.com.
Posted on Jun 17, 2007
SOURCE:
Printhead error
A firmware update for your model addresses the "printhead error" on your printer. First, get rid of error message on the display screen to successfully update your printer firmware.Open the cover to remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened.
Then proceed with the firmware update. Please visit the Lexmark website at http://bit.ly/s405fw to download and install the firmware update.
Should you need further assistance, please don't hesitate to contact Lexmark Technical Support Center.
Mar 10, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Error 6500 displayed on screen already tried holding ON button for 10 secs .. released and pressed for another 10 ... printer resets but as soon as the wifi kicks in within the starting cycle same error...
Hello! Welcome to FixYa
First try this to solve error 6500:
Firstly Reset the printer and
Turn the printer off with the Power button then disconnect the data cable from the printer.Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Turn the printer on. If this works you have solved the problem If this not works then try the next step:
After confirming that the printer is powered on,open the paper output tray and Open the top cover and wait until the print head moves to the center then Open the inner cover and check that ink tanks are properly seated.Press down on each ink tank until a click is heard.Close the inner cover and top cover. Also do you have any kind of data equipment like a camera connected, if so this could be causing the problem as well. Unplug it if so and see if there is still the problem after the above steps then final & best option is to take it back where you purchased it or contact Canon service center about the error code.They will surely solve it.
I hope this solution was helpful for you.
Don't hesitate to let me know if you want any further assistance
Thank you for using FixYa, Keep visiting!
Sep 11, 2011 | Canon PIXMA MX340 Wireless Office...
The instructions tell me to lift the lid, but I don't know how, it seems to be locked, is there something underneath I need to push or pull. I need to change the ink cartidges
On this particular printer there is no locking mechanism to access the ink cartridges. In order to open the cover, use a single open hand and place your fingers just underneath the screen on the front, and pull upward. The entire scanner piece should raise and a plastic bar on the right-hand side will lower down to prop it open.
If you're having a lot of trouble opening it, you may want to check around the sides of the printer to see if there is any tape leftover from when the printer was packed in its original box. When they ship a printer it is always covered in tape to make sure that nothing falls open or breaks before it's delivered, and there may be a piece of clear (almost invisible!) tape left over preventing the printer from opening.
Once it's open, the ink cartridges should come to the middle. Press down on the small lever on the print head (the ink cartridge holder) to pop the cover open so that you can install the cartridge.
Hope this is helpful!
May 09, 2011 | Lexmark P6350 All-In-One InkJet Printer
The printer (Lexmark X5340) display "cover open"
Short of slamming the cover closed there is a small tab that tells if it is open or closed. It should be located on the lower right hand corner. Once you find it just put a small piece of paper there or plastic and you should have no more problems.
Mar 30, 2011 | Lexmark Office Equipment & Supplies
I have loaded a colour cartridge a and a black cartridge into my 8450 printer and now all I get is the 05f37c2b error code apear on the screen
Please try the following:
Remove the cartridges that you just replaced. Ensure that they are compatible with your HP 8450 printer. Make sure that none of the electrical contacts on the printer or cartridges are damaged and that there is no obstruction in the cartridge port. Turn printer main power off, and then back on with the cover closed. If the error code is now gone, open the cover and install the new cartridges as described in the manual. Also, did you remove the protective nozzle covers from the cartridges?
Good luck,
GaugeMan
Mar 06, 2011 | HP Photosmart 8450 InkJet Printer
I bought a x3470 printer second hand. It wont respond when i press buttons on printer. It says door open in display window.
Here is a great article on how to try to resolve the cover open error on the Lexmark X3470. http://bit.ly/aoOtEP
Feb 27, 2010 | Lexmark X3470 All-In-One InkJet Printer
Compatible ink cartridges not working
either the cartridge circuit is damaged or there is a problem with your printer. To make sure, you will have to try the cartridge on another similar printer. If it works on another printer, the problem lies with your printer.
May 23, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How do get a page count off of a canon 9000L
Open the 2 panel key covers.Press dataregistration button and then the # key.1sssw will apear on the display.Press the arrow button untill printer is display.press set button,arrow button again untill print count is display press set and then the counter will be displayed.To return to normal press stop.
Mar 09, 2009 | Canon LaserClass 9000L Plain Paper Fax
When opening the phone, no display apears for about a minute
the flex cable that connects the two parts is broke u need to go to a cellphone service and replace the flex
Mar 31, 2008 | Sony Ericsson Z610i Cellular Phone
Scanner cover open
Simply force the button front into position by pressing it with both hands.
In case your wont be successfull stick a thick tape at he position were the cover switch contacts the inner cover (opposite to the display towrds inward is a double plastic contact).
Oct 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
42 people viewed this question
Top Philips Office Equipment & Supplies Experts
Damen Wong
Damen Wong
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
