SanDisk Sansa m250  MP3 Player
Problem for SanDisk Sansa m250 (2 GB) MP3 Player
Sansa m250 freeses on power up
By Pradu on Jun 17, 2007
My sansa m250 is freezing upon power on and is not operating.It's now been 4 hours since I opened it. It has been frozen for at least 10 minutes since the last time I tried to turn it on. I tried reinserting battery, leaving battery out for a few minutes, plugging into USB when off, then when on. Nothing works. It starts "initializing" then goes to SANSA screen with V4.0.44A at top and m250 2.0GB at bottom. That is where it is still now more than 12 minutes later. How can I upgrade firmware if it is frozen? My system also does not recognize the player.
Same Problem
Nov 24, 2007
-   Actually my boss has the player and asked me to look into fixing it. It initializes then doesn't do anything. Changed battery with no change in results. PC will not recognize it.
I removed the battery and held in the off button as suggested by san disk but it didn't work either.-   Guest
Nov 17, 2007
-   Upon Starting My SansaM250 2.0GB, it starts wuth a
| Sandisk |
|initializing |
___________|
& From there on it goes to a
Sansa
m250 2.0GB
This makes me angry as it makes my daily 1/2 bus trip to school really boring.
I have already written to Sandisk about this problem.
-   Moolahman
Nov 13, 2007
-   For the past week my m250 freezes right after Initializing. Now it won't turn on at all. I've tried new battery; nothing works. It's only 6 months since I bought it. Any ideas or will you have to replace it under warranty?-   dorite
Solution #1
posted on Sep 25, 2007
Somewhat Helpful)
amakorkos
Rank: Guide
Rating: 75%, 10 votes
Hi there!
I've got a brand-new solution to this dead-end problem.
BUT, the downside is that you'll need another similar player.
Here's what I've done to unfreeze my Sansa m230.
1. I've opened the cases of both our Sansa m230s.
2. Connected the healthy one to the computer via USB.
3. After it was connected I've hot-swapped the "Samsung k9k4g08u0m-pcb0" memory chip with the one, which was causing the problem.
4. Finally, I've formatted it through WMP10.
Only synchronizing in MTP mode using WMP11 since.
Hope that helps.
Amakorkos
Was this helpful?
Yes
No
Solution #2
posted on Jul 26, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
throw it against the wall because sandisk is aware of this problem and does nothing about it... they should replace them for free but they don't... race condition in that firmware screws the player up...
Popular Solutions for SanDisk Sansa m250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa m250 MP3 Player
Do you recommend SanDisk Sansa m250 (2 GB) MP3 Player?
Answer
Answer
does the player need to be turned on to add music?
Answer
sansa sandisk m250 can't access recorder. when I push white button on player, fm/am/, recorder it... (More)
Answer
Hi. My computer will not recognize the sansa e250 ipod when i connect it anymore. Can you please... (More)
Answer
I have a Sandisk 2.0 GB MP3 player. It loses it's charge with the battery fully charged after about... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa m250 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 441
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
