Question about Sanyo DS31520 31" TV
PSCAN Message Displayed
When I go to video mode on my Sanyo DS31520 31" TV I get a split vertical screen and the message PSCAN right in the center of the TV screen. This only occurs in Video mode. The DVD play works fine, but displays on the two screens.
How do I fix this problem.
Thanks
You please use dvd remotby press mode button
Posted on Feb 06, 2009
Whenever I try to watch a DVD the screen splits and a message reads "PSCAN"
You need to do one of two things:
1) Look at the back of the DVD player for a switch that is labeled with " PROGRESSIVE SCAN', you need to set it to OFF (since you are using Composite Video jack (Yellow RCA jack) output of the DVD to feed your TV, but the DVD player is set to PROGRESSIVE scan mode, taht is why you are seeing "PSCAN).
2) Use the component video input/output instead by using 5-wire cable set (Red, Blue, Green for video, and White and RED for audio).
Sep 03, 2011 | Sanyo Televison & Video
When i load a DVD, I get a split screen and a large PSCAN!
Probably fix it with the remote. Look up progressive scan in your manual, and turn it off.
Apr 29, 2010 | Sceptre X240BV-FHD LCD TV
Pscan message and split screen
well on your memorix dvd player you will get a orange triangle that says pscan (progressive scan) you will go to the back of you dvd/vcr and on the right hand side you will see a switch to turn on and off the pscan you will switch it off and you will be set to go
Aug 23, 2009 | Memorex MVD2022 DVD Player
The screen is split ! PSCAN
Take a look at the back of the dvd player there should be a switch that says Progressive scan on/off. Switch it to off. Problem solved !!!
Nov 30, 2008 | Memorex MVD2042 DVD Player
PSCAN MESSAGE
pscan showed up on my dvd player and I shut the switch off on the back...all good! thanks for the inpu!
Mar 08, 2008 | Memorex MVD2042 DVD Player
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
PSCAN! Message
your picture and picture setting or may have FLEX CONVERTER PROBLEM need to call local tv shop
Feb 06, 2008 | Hitachi 43FDX01B TV
Pscan
i had the same problem. When i played a DVD on my Memorex player, a double screen displayed and a PSCAN message displayed in yellow. I simply toggled (switch) the PSCAN switch on the back of the DVD player. -Mike / Florida
Nov 21, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Sanyo DS31520 31" TV Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
