Question about Gibson GAK124Q1V Air Conditioner
Gibson gb3bv-024k-a heat and ac
My ac works fine but when i try to turn on the heat the heating coil doesn't turn on.the blower works but theres no heat.the wires were tampered with before i moved here.i tried to look at the diagram but the words are faded.can you help me
    Problem Solver:
  • 11 Answers
Take it to your local repair man and get it fixed
Posted on Jan 15, 2009
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Ho to ajust air handler blower speed on a Gibson airhandler GB5VM
The Gibson GB5VM's ECM variable speed motor includes 12 field-selectable cooling airflows and 4 heating airflows to match any application. This Gibson air handler's quiet blower operation is achieved through extra quiet and smooth blower on and off cycles. Consult with your INSTALLATION & OPERATING MANUAL provided from your local Gibson Installation Team. If you cannot locate one, you can call GIBSON 24/7 at toll free 888-701-5040
Aug 31, 2014 | Heating & Cooling
The Front Heat / Ac Work's ! ! ! ...When It Wants TOO
there is a blower relay circuit board located right by the blower motor which sounds like your problem to me i've worked on several that had the same type problem and thats what it was. the two blower motor wires will plug into it and there are two screws that hold it on
Apr 23, 2014 | 1996 GMC Safari
1999 VW Passat AC/heat doesn't work? The belt broke this summer? I was told should still blow heat even if no belt?
If you are talking about the belt for the ac compressor, yes the heater should still work.
If the blower is not working, you will need to have the blower motor checked for voltage and ground.
Dec 18, 2012 | 1999 Volkswagen Passat
Front blower motor doesn't work but works in rear
Change the. Blower motor resistor. $25 part near the blower. Chevy suvs are famous for bad blower resistors
Sep 10, 2012 | 2002 Chevrolet TrailBlazer
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
I have a 2001 lincoln ls and the heat does not work
check to make sure heat flaps are opened,check fuses for blower motor or check blower motor
Mar 08, 2009 | 2001 Lincoln LS
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Heat and ac controls not working. AC is on all the time and heat doesn,t work. air only comes out on defrost.
you might need a new cluster. try changing what is called the blower motor resistor. it's about 13 bucks. remove the plastic cover under the glove box and remove 2 bolts that hold it in. it's the only thing under there with wires. swap it out bolt it up and your done
Aug 14, 2008 | 2000 Dodge Stratus
Gibson GAK124Q1V Air Conditioner Logo
415 people viewed this question
Top Gibson Heating & Cooling Experts
Paul Carew
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
