Question about Palm m515 Handheld
The right hand corrner is all black and looks like ink
  • 115 Answers
It sounds like maybe the screen got a crack, fracture in it. It is LCD and it 'looking like ink' kind of points in that direction. It will have to be replaced. If you are up to the task, many replacement screens are available on the internet. I would try eBay first, that is where I got my last one. But unless you are totally comfortable with opening up you m515, take to a service tech.
Posted on Jan 24, 2009
Why does my epson 1400 feed paper straight threw instead of printing?
first, are you on a screen that has text on it to print. say a word document? Not a web page. second, how long has the 1400 been sitting before this happened? if a long time then the ink head may be clogged. Try printing in gray scale only and then in color and see if the same thing happends. Third make sure all print tasks are cleared. normally in the bottom right hand corner you will see a printer icon. if youclick it it will tell you how many jobs are waiting. clear them all. by pausing and then canceling them. (if they are there.) if none of those exist then look for the ink pad on the inside of the printer to the right. ( you will have to see if the head is moving left and right to do this.) if the printing head is moving left and right and you dont see anything stuck like paper and such in the machine then you need to find out if the black foam on the right where the print head parks when its done and shut off is wet or not. this entails watchin the print head go to the left and then shutting down power to this printer by unpluggin it. (this is not a switch off it needs to be unplugged from the 110 outlet) then if you can feel by a Q tip if you donw want to get your hands inked and see if it comes up with colors and black. if it does not then the ink heads or ink or both are dried. then do a search here on Fixya to look for clogged ink heads
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Erreur code : 6A00 What to do ?
It's most likely a little sponge on the very right side beside your ink. If you open the top, push your ink to the left then look to the VERY right...there is most likely a little spongy thing that if you push down (your hands WILL be black after this) and reset...it should work.
Dec 19, 2010 | Canon PIXMA MX850 Multifunction Printer
How does the top come off. snap off??
After you've unplugged the power cord, pull up on the top a little and look for 2 metal snaps under the top lip approx 6" from the front corners. Use a standard flat screwdriver to push against the snaps and release the top from the unit. Watch out, the front will come forward and the drum may fall out of place, so have an extra hand there when you do it. Good luck.
May 15, 2010 | Frigidaire GLER341A Electric Dryer
Black marks on the side of page
You are right the drum needs to be replaced. the coating wears down and starts making marks I sell them for 55.00 complete or just the drum for 22.00 It's easy to install a new drum with a screw driver and a pair of needle nose pliers. steven 818-888-0006
Mar 10, 2010 | Lexmark E250dn Laser Printer
I donot know how to put ink in my printer jnhb55564
first turn on you printer.
second open you cover then you will see the print head cartridge is running out i think he will stop in you left hand side or right hand side.wait for he stop running.
third after stop running plug out ink just press down ink about 45 degree then you can take out ink.remember when you put out ink see number ink before installation.
4.when install ink remember to take out plastic sticker gum inside ink.now install ink jus put in inside by 45 degree the press up him after that is ok
5.close the cover and try to print.i think black ink in left and colour in right i no sure but try .... ok....
Aug 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
There is no ink on the paper
Hi Kontiki28. It seems you either have seriously blocked black ink nozzles, or you have faulty black ink nozzles. You can try the nozzle cleaning method described below, but remember it can take quite a while.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check.
If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Jan 08, 2009 | Epson Stylus C88 InkJet Photo Printer
My officejet 7680 allinone printer misses printing black and smuges the paper
remove the black and see if there is any ink build up on it. look into the right hand side of the unit where the carriage rest on the service station and if you see a ***** of black ink then the unit needs to be cleaned out. USE A FLASHLIGHT TO SEE THERE
Oct 04, 2008 | HP OfficeJet d145 InkJet Printer
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I cannot sign into my windows live messenger but if i turn off trend micro i can, i have allowed it in trend micro and it still won't sighn in
Follow this steps.
1:Open up your internet explorer. Go to the tab on the top right hand corrner that says Tools.
2:Now go where it says connection on the bottom and now click on LAN Settings.
3:On the bottom where it says "Pryoxy Server, if that box was checked in, thats what was causing the problem.
Thank YOU!!!!!!!!!!!!!!
Jul 17, 2008 | Computers & Internet
Ink leak
hi , buddy you need a major servicing to be done, the ink absorbing pad is fully draining , it needs to be replaced or cleaned but you will need to open the printer..
Nov 18, 2007 | HP PSC 750 All-In-One InkJet Printer
Palm m515 Handheld Logo
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
