Question about Pioneer DV-575A DVD Player
No Power Hi I have a Pioneer DV-575A that is completley dead,i have checked the fuse,the power supply is working fine,so the fault must be on the video out board,i have all the right voltages on the CN301 connector but from there i do not know where to go,got any idea's? Regards
  • 790 Answers
Ok! make sure ur IC regulator is good. like the 7805 or 7812 or 7809 u make sure that the following ICs are correct in voltage! 7805 is for 5V. 7812 is for 12V. 7809 is for 9V MAKE SURE THAT IS EXACTLY IN VOLTAGE!
Posted on Aug 15, 2007
SOURCE:
DV-585K (PIONEER), My player is not turning on. I've already check the cord, fuse and the switch and they are all good. What else could I check or is there any parts that needs to be replace if problem is...
The most common caused why your unit didn't power up was because of faulty power supply board. Since you've already checked the AC line, the fault now is quite technical if you haven't an experienced in electronics. The board must check the faulty parts like the fusible resistor in line with the shorted voltage regulator IC/transistor (mounted in heat sink), dried electrolytic filter capacitor, open/shorted chopper transformer, shorted diode. You must know how to test this parts to pinpoint where the fault came from. If you can't troubleshoot the board yourself, you may replaced it by inquiring to your local pioneer service center for the power supply board's availability.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 24, 2011 | Televison & Video
Power is not working complite seat dead
hi,
check the power cable first. also the power at the wall out lets.
if ok the you have to check the input ac fuse of your receiver. your recever has problem with its power supply stage, that's why there is no standby light also. fist of all check the fuse. then check the standby transformer is it faulty or not. the system will power up if the standby transformer is ok. standby transformer is a small transformer near the mains transformer. check these things first, if u need any further assistance feel free to contact me through fixya.
ok
Jan 24, 2011 | Pioneer VSX520 Receiver
My Dv-C36 was working last night, now it has no power. I figure it has to be a fuse. Is that possible? If so can I change it?
Yes its possible the main fuse is on the power supply board on the left side when looking from the front. Its a 2 amp fuse easy to replace there are two more on the same board but you must be able to solder, they are pico fuses and very small.
Jan 16, 2010 | Pioneer DV-C36 DVD Player
Pioneer dvd player showes prgsve.. what should i do..please help!!
if the remote control got it one push button with this legend push it and try to disable
Oct 27, 2009 | Pioneer DV-575A DVD Player
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Soniq dvd qmt 300 colour drops out
I have a problemn with Pioneer DV-300, it shows "prgsve", I would like to know the method to solve it!
Sep 20, 2008 | Pioneer DV-575A DVD Player
Firmware upgrade
it seems as if i need a firmware update cause it takes very long to read a disc if it reads it at all.
Jul 27, 2008 | Pioneer DV-575A DVD Player
PDP-502MXE dead set
hi all,
this problem lis the power supply board. be aware that pioneer pdp-502mxe has got 3 versions and all 3 power supply boards are different so before ordering a new or reconditioned one check the part number on the power board itself.
pioneer is not replacing the boards anymore.
check on ebay.co.uk
i did sold so many parts from this model.
thanks
Jan 08, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
NO Power
If you have a voltmeter and some tech savvy, you could check the power supply section for the presence of the required voltages. You should see a +5, and one or more other voltage sources, like +12 volt. If your power supply is dead, then a component failure in the power supply is likely, or there could be a short/overload elsewhere that is keeping the p/s in protective shutdown.
Jun 13, 2007 | Panasonic AG-DV1000 Mini DV VCR
Pioneer DV-575A DVD Player Logo
151 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
