Question about Dishwashers
Technika TDX6 wont start
I have a Technika TDX6 just out of warranty. When I programme to wash dishes all relevant lights come on. I can hear a humming sound from machine but machine wont start. It appears that the water is not pumping into the machine. Any help would be greatly appreciated.
  • gavinramm May 02, 2009
    i have the same problem but when I change it to a different option it does the same thing,
    I have the same issue, but when I change it to a different setting it still does the same.. i turned off the washer for a day at the power point. once I turned it back on it worked but only for one wash.. now its doing the same thing
The small black relay on the main circuit board was overheated and the contacts were burnt.
If you held the start button in it would sometimes start.
Expensive fix is change the complete circuit board or find someone with electronics experience to change the relay which is a common 12V 10A type i.e. NEC MR301-12HS.
Posted on May 20, 2010
It appears the problem was some sort of electrical fault. I changed the setting on the wash cycle from setting 5 to setting 1, pressed start and the dishwasher commenced its cycle. I then changed the setting back to five and the dishwasher continued to work. I can only suggest that there was possibly some connection problem in the setting knob. Thanks anyway for the assistance.
Posted on Jan 16, 2009
Can I get a free manual for Technika TDX6 stainless dishwasher
Try Googling (Technika)(TDX6)(manual) without parens.
Nov 01, 2017 | Stainless Dishwashers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Sep 20, 2008 | Washing Machines
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Dishwashers Logo
981 people viewed this question
Top Dishwashers Experts
