Question about RCA 27V520T 27" TV
RCA L26 WD12 G094E1985
We purchased this TV on clearance at Walmart's no booklets and no warranty... The TV was working fine when we went to bed last night and this morning all we get is a sound and no piture... It did this yesterday morning so we turned it back off and then on again and it worked fine... But this morning turning it off then back on doesn't help .... Any suggestions?
  • Don Williams Jun 18, 2007
    This has been resolved....
techman
  • 3130 Answers
SOURCE: F36550 RCA 36 in TV
Hehehe Its all in a matter of taste I like sony and Mitsubishi. You like RCA you get what you pay for. These sets are good for the L401 in the horizontal drive circuit to cause your problem as well as a blown fuse and a shorted horizontal output trasistor and the flyback transformer. if its anything Im thinking off the repair cannot be done by a handi person and should be taken to a pro and will cost in the range of150 to 225.00 for this repair. good Luck
Posted on Jul 27, 2006
  • 1030 Answers
SOURCE: will not come on
well .. the smell is not good.. that usally idcates high voltage arching... 90 percent chance its what is called a flyback. and when they go the horizontal out put goes...not a difficult repair for technician.. but you have to get right parts
Posted on Dec 10, 2007
salt56
  • 373 Answers
SOURCE: rca ctc195 big screen tv trouble
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Posted on Dec 30, 2007
freetek
  • 5569 Answers
SOURCE: RCA 35" no picture, clicking zapping sound
What you are hearing is the discharge of high voltage which if it hasn't already failed, will fail if allowed to repeat too often.
The only thing you might try after unplugging the set for a minimum of 24 hours, is to remove the back shell (shouldn't be more than 8-10 screws around the perimeter and perhaps one or two around the connector cutout) and with a clean paintbrush and a vacuum cleaner with the nozzle held close to the work area, brush the CRT (picture tube) free as possible of accumulated dust, paying particular attention to the area around the large rubber cap with a cable leading to the circuit board.
I can't stress enough that the set must be ignored to allow the 25,000 plus volts that are present on the CRT when operating are given a chance to 'bleed off.' This voltage doesn't often kill anyone since it is a short-term discharge with the set off but I have seen it punch a hole through a thumb.
If you are lucky, the horizontal circuit is not in its death throes but only discharging through a layer of typical household crud. Unfortunately, this will not likely help you and you will require a tech to locate the problem. Good luck finding one that isn't dead or retired yet; we are dwindling.
Posted on Sep 29, 2008
SOURCE: RCA Scenium: l5000yx1 - turns on and off by itself.
Mines did the same thing. I had to get a new bulb $200 on line and pay someone $200 more to fix some wires that had pulled apart when we changed out the light. But now it works great!
Posted on Nov 22, 2008
How do i get my kodisolutions to work when i try to login it keep saying not connect to the server it was working fine yesterday and last night before i went to bed it was working fine dis morning it want...
Unplug the power from the modem and the router, wait about 30 seconds and plug both in.This will reboot the server and your device should resume function
Aug 31, 2018 | Televison & Video
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Sep 26, 2009 | Samsung 50 in. Plasma TV
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Viewsonic problem
Have you checked the SCART leads?
Usually seems to be the cause of this kind of thing.
Nov 07, 2008 | Televison & Video
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
