Question about Kenmore 659 Electric Dryer
Door interlock safety switch tab is broken
Where can I get the part in Vancouver, WA / Portland, OR? Presume I must take top off -- Does it pop off with spring clips, or are there concealed screws?
    President:
  • 1,214 Answers
The top pops up. Insert a screw driver into the slot about 1 inch below the top. It hinges at the back. There are springs on the left and right.
BE SURE TO DISCONNECT POWER BEFORE SERVICING!
Try Sears Parts Direct, or you can look up the closest parts and service center from that web page.
Posted on Jan 15, 2009
How do you remove and install a neutral safety switch for a 1993 mitsubishi Expo SP manual transmission?
I presume you mean the clutch interlock switch on the pedal assembly. There is no neutral safety switch for a manual transmission. The interlock switch requires the clutch to be pressed when starting.
The switch has two 12mm (or 14mm?) nuts to adjust the position of the switch. There's a wiring harness connector so the switch and short cable can be removed.
SD
Jun 09, 2011 | Mitsubishi Expo Cars & Trucks
Sharp microwave carousel R330J 1100 watt. When the heating cycle is started the microwave light flickers on and off and there is a clicking sound. Initially high voltage fuse blown. replaced fuse and...
Hi and welcome to FixYa. I am Kelly.
1st the model number appears to be incomplete. Not an issue at this point but will be if you need parts.
You most likely have an interlock problem with one of the 2 door switches or the door interlock mechanism is broken.
There are 3 safety interlock micro switches activated by the door. One for the light, one for the Magnetron and one for the control panel power. If the problem persists with the Magnetron disconnected. The Magnetron safety interlock micro switch is supposed to blow the fuse if the unit is energized with the door open. Check continuity of your door interlocks. Pat particular attention to the NC (normally closed), C (Common) and NO (Normally Open) contacts.
NC should read to C and when the switch is activated read open at which time the NO contact will read to C.
I really suspect a bad microswitch.
Thanks for choosing FixYa.
Kelly
Aug 21, 2010 | Vacuums
Dead, replaced fuse and it blew again.
The fuse is connected directly in series with the monitor switch. If it senses one of the door switches bad it will blow the fuse, this is there as an added safety to make sure the oven will not work without the door closed.
There are usually three and sometimes four door switches just inside and to the left of the control panel that are activated when the door interlocks with them. One of the switches is most likely bad. Typically it is the primary interlock which is on top. It can be checked with an ohmmeter, usually you can see it broken as the plunger will not go down or come up like the others.
May 10, 2010 | Maytag MMV1153A Microwave Oven
Electric Lawnmower stopped working.
You were NO help at all. I asked for a location to have an electric lawnmower repaired in my area. You gave me a source 2500 miles away. Obviously I cannot count on assistance through this site. What happened to REAL PEOPLE who can offer some intelligent reply? If I could repair a lawnmower, why would I need to ask you?
Dec 02, 2009 | Black & Decker Garden
My hotpoint few10 washing machine wont work,it wont come on at all and none of the lights at the front come on
On some front load clothes washers, the door has a safety interlock switch that prevents the washer from operating if the door is not fully closed (or the door / safety interlock switch is not aligned or broken.)
I would check that first. Please report back, OK?
Apr 20, 2009 | Hotpoint First Edition FEW10P Front Load...
Cannot open the battery compartment to change batteries
I give up...battery compartment so bad I'm returning the camera.
Jan 11, 2009 | Canon PowerShot A400 Digital Camera
GLV BK-2 top latch broken at fish neck when retrieving.
The latch engages the interlock switches. If its broken it won't work. You will have to look inside and see if they have switches on both the top and bottom to see if you have swap them.
You should be able to order replacement latches.
The safety switches keep the oven from working with the door open so you should not disable even one of them.
Jan 09, 2009 | GE Advantium 120 Convection/Microwave Oven
Safety Interlock "Switch"
This is not the safety interlock switch. This flat bar keeps shredder paper from backfilling into the cutters. The safety interlock switch is a vertical slot on the body that a tab on the top fits into.
Feb 29, 2008 | Tech Solution TS-4500 Shredder
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Kenmore 659 Electric Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
