Question about Canon BubbleJet i560 InkJet Printer
Printer does not follow margins indicated
Whenever i print a Microsoft 2007 word document, there's always this big margin allowance on top of my printed document. If i modify the margin to .5" all sides, i'll be having an approximately 1.75 gap on the top of the page, while the rest is fine. please help. does this have something to do with my printer, or is it with the program itself? I'm using Windows Vista by the way.
  • Brittany Araneta Jun 18, 2007
    Hello jackboy :D,
    Just now i found out that microsoft office 2007 has a compatibility problem with Vista. When i installed office 2003 and printed the document, everything turned out to be fine. I guess i'll be using office 2003 for the meantime. (it's better anywayz). Anywayz, thanks a lot for the advice! :D The printer's not the culprit after all.
    Genius:
  • 2,985 Answers
Ahhh Vista - has a lot to answer for , is this another little glitch I wonder? Would it be possible to save a document to disk and print it on the printer from another XP computer for example - just to check things that way. I do suspect that this is a program thing and not the printer.
Posted on Jun 17, 2007
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
THIS IS NOT AN ISSUE WITH MY MARGINS. I have Microsoft word 2007, an HP Officejet Pro 8500 Premier and windows vista. After some research I found a commonality with my problem and these three operating...
The problem may lie in the printers setting for the margins. Do you set the margins only in word 2007 or do you check the printers margins too?
Also the issue may lie with the printer having the incorrect paper size
Have a look in the printer properties (When you go to print, its beside the printer selected) and look through there and see if there are any issues.
Dec 02, 2009 | Toshiba Satellite P205D-S7454 Notebook
I am not able to print the portion from exactly start of the page of ms word document, why? Not able to show it in print preview??
Hello and Welcome to FixYa!
The portion within the Margins can only be printed, lessen the top margin at bit.
I remember the top margin for default is 1', change it to 0.5' or 0.6'
In Office < 2007 (Margins are in File > Page Setup)
In Office 2007 (Margins are in Page Layout > Margins > Set it to Narrow)
Note: If you printer is non-Laser (I mean if it is Ink-Jet) Do not make the margins too less, the printer won't be able to print it.
Sep 27, 2009 | Microsoft Office Word 2007 Upgrade Version...
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
131 people viewed this question
Clive
Clive
old marine
old marine
