Question about Dryers
Kenmore Series 80
The belt broke on the dryer and the pulley assembly came off. Where does it go and how does it connect. Also, could you tell me the routing pattern for the new belt installation.
  • 1,214 Answers
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Posted on Jan 15, 2009
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
My Kenmore 80 series gas dryer will turn on but won't spin
Hi, Sounds like the belt broke.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Feb 10, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
I have a Kenmore Series 80 dryer and the belt broke. The pulley came off and I don't know where it goes or how to put it back on. I also don't know the routing diagram for the new belt. Please help ASAP I...
it goes on the shaft of the electric motor the belt goes around the drum should be a set screw on pulley reattach to shaft tighten then looosen bracket on motor apply tension and tighten you may have to go to the hardware st ore and get another screw if yours is lost as a tip apply red loctite to the threads to prevent it from vibrating loose they have that at the hardware store or auto store
Jan 15, 2009 | Kenmore 62622 Electric Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Idler pully
there has to be a spring on the idler to keep it pulled against the belt
Mar 01, 2008 | Kenmore 62622 Electric Dryer
Dryers Logo
341 people viewed this question
Top Dryers Experts
