Question about LG Computers & Internet
Cd-rom won't acknowledge that i have a disk in drive
Tried to update driver... says no software is found.Is it listed under something else? what? or is it not there at all?where can i find this software and what price range are we talking about?
  • Nikola Malesevic
    Nikola Malesevic May 11, 2010
    Did you try with multiple CDs? How did you upgrade drivers?
    You do not need any software other than operating system to read data from CDs.
  • 201 Answers
SOURCE: CD ROM Drive doesn't read CDs!
These compact CD drives break more easily than standard desktop drives. Your drive will probably need to be replaced. First I would try removing and re-inserting the drive (maybe even a few times) There is probably one screw or a slide switch under the laptop to allow the CD drive to be removed. IF that does not help, have you cleaned the lens? You have easy access to the lens when the drive is open. If you have any camera lens cleaning equipment use that, if not 91% rubbing alcohol and a q-tip will work. Just don't rub too much or apply much pressure at all. Just lightly sweep away any dust. If none of the above work I would look for a replacement. The CD burner or DVD burner drives are typically more reliable and last longer.
Posted on Jul 07, 2007
  • 383 Answers
SOURCE: My cd/dvd rom is not found in My computer but it is installed (code 39)
What programs can I use to burn or create CD's on my computer? A standard CD-ROM drive is not capable of creating a CD even if you have any of ... If you're running version 10 or higher and have a CD/DVD burner drive .
Good Luck, Please dont for get to Vote/Thank You
Posted on Dec 20, 2007
SOURCE: Tray starter and InstantWrite Control Center have stopped working!
I just read on another website that the program "Pinnacle CD/DVD Suite" is the problem. It gets installed along with Wordperfect and it needs to be un-installed. I had the same problem with the 2 pop-ups and then when I tried to put in a cd with pictures on it, my computer crashed. I have just un-installed the Pinnacle CD/DVD Suite on my computer and the messages are gone and I can run cd's again!!
Posted on Mar 16, 2009
SOURCE: Philips CD-ROM drive stopped working
may be there is some problem with the hardware. if the product is still in warranty then call them or get it checked from a technicain.
Posted on Jun 18, 2009
bharat_s
  • 178 Answers
SOURCE: LG CD ROM not found it need toupdate the driver
your problem is very clear... your cd-rom is corrupted.. install new windows... NOTE-do this only if your cd drive is NOT displayed in my computer..
please vote for me...im sure this will solve your problem...
Posted on Sep 29, 2009
I need to update my drivers for cd rom
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Aug 14, 2012 | Microsoft Computers & Internet
I'm currently using Windows XP, and have: TSSCorp SH-S182D and SH-S183L. Neither are currently working - they show up in the Device Manager, but the Samsung drivers I try to update them with never...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
When I put a blank CD in, it does'nt acknowledge it, therfore can't burn :(
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 24, 2011 | Toshiba Computers & Internet
K8NE- Deluxe won't acknowledge my new SATA DVD. Is there some Bios setting to fix this? Or anything to fix this?
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 10, 2011 | AMD Asus K8N-E-DELUXE nForce3 Mainboard...
I have a Systemax Venture Microsoft Windows XP Pro Version 2002 Service Pack 3. The system will not longer play dvd's or cd's and cannot burn cd's as well. I'm not sure if something has...
Well the fact that when you put in a cd it does not see it indicates that either the CD Drive is not being detected or the drive has gone faulty and needs replacing.
First Look in the bios of the computer to see if it is seen the drives section. If it is there then look in windows under control panel , system, device manager. Now look under DVD/CD Roms drives (this may differ slightly in XP) to see if in there with no error against it. If not and not in the bios either then the drive has failed. If however it shows in DVD/CD Roms with no error then try a different make of cd/DVD. If this works then the Bios of the drive will need updating. This info is on the manufacturers website. Good luck.
May 10, 2011 | Systemax Venture PC Desktop
Dvd burner wouldn't close session - won't eject - now computer not acknowledging disk in cd-rom and it won't manually open. Rebooted several times. Rebooting taking longer now.
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
if your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver
hope this helps
Apr 28, 2011 | E-Machines emachines (emachinees) CD-ROM...
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Cd rom not working
Have you tried unplug cd rom drive then reboot and plug it back in should initiate the found new hardware wizard if it does not initiate the wizard try control panel add new hardware wizard and follow the prompts you will get to the screen asking you if you have already connected the hardware click next will open a screen with all your connected devices hopefully your cd rom drive will be listed if not it could be a power\lead problem or a driver problem
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 03, 2010 | Dell Computers & Internet
When I insert a disk nothing happens, it makes really loud noises asif its about to take off. This carrys on and my computer does not recognise there has been a disk inserted.
The driver for your CD-ROM needs to be UPDATED. click start, then control panel, click performance and maintenance, then click system, click the hardware tab, then click DEVICE MANAGER.under the CD/DVD ROM DRIVES, your CD-ROM should be listed. It may have a "?" mark or "!" to show the driver is out of date. If so, then right click on the device, click the "driver" tab, and click update driver. If the driver is updated, but the CD-ROM is still not functioning, follow the same steps, however; when you right click the device and enter the properties, instead of entering driver, click the "PROPERTIES TAB: and UN-CHECK the box in the DIGITAL CD PLAYBACK. If that does not work, then search online for a driver that is compatable with your windows system,
Nov 22, 2010 | Compaq (120192-B21) CD-ROM Drive
Computers & Internet Logo
57 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
