Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer Drain Clogged
I started with the water leaking out of the freezer side, I found the drain iced over, but I can't seem to clear it... I've use significant amounts of hot water and completely defrosted the freezer side. How to I check the other end of the drain and where does it go? I don't have easy access to the rear of the refrigerator, but completely removing it appears to be my next step. Any insight would be helpful. Thanks
  • witz_tim Dec 22, 2008
    I can't find the drain for the freezer, but have water frozen at the bottom of the freezer.
  • dano5659 Dec 28, 2008
    I have the same problem, but don't know where to look to locate the freezer drain line. Is it the same tube that supplies water to the ice maker?
I had to remove the shelves out of the freezer then removed the plastic casing located in the side rear, this will expose the cooling cords, underneath the cords is a medal drip pan, I removed the single screw and removed the medal drip pan this gave me access to the drain, I used hot water which seems to have cleared up problem.
Posted on Jan 11, 2009
  • 87 Answers
I use a turkey baster and force hot water right down the drain hole. If still blocked I push a coat hanger wire down the drain, usually works but you need patience with the hot water.
Posted on Jun 17, 2007
We have the same problem. We found the drain tube kinked near the catch pan at the bottom of the fridge. We cleared the tube by defrosting the fridge and placing a small hair dryer in the fridge blowing on the drain. Even after clearing the drain it still freezes up once in a while. It seems to be an inherant problem with this model. If I find a permanent fix I will post it here. I hope this helped.
Posted on Jun 30, 2007
SOURCE:
Water is leaking from an opening in the back surface of the freezer compartment and forming a puddle that freezes and then melts, dripping under the freezer door
If you remove the shelves and bins from the lower section of the freezer you will notice in the back of the freezer your drain pan is clogged. Turn off the freezer and use a turkey baster to add hot water to the pan until you clear the clog. This can happen when foreign object slow the water leaving the freezer during defrost and cause it to refreeze stop water from leaving the freezer. Not a big problem or difficult repair. Just clear the drain and remove all the ice from the drain pan. Could take 15 mins or so to complete this..
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint CSX22GR side by side refrigerator / freezer. Ice in bottom of freezer and water leaking on floor on freezer side. How do I find the problem??
The problem is the defrost drain is clogged, the drain is located on the lower part of the back panel and can be gotten to be removing the drawers and to clear drain push a wire hanger through it till small hole delvolopes then flush w/hot water till completly clear
Jul 25, 2011 | Hotpoint Refrigerators
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Water leaking from freezer side of side by side refrigerator..model MSB2354AR
Sounds like a clogged drain, If ice is on bottom of freezer floor then it is def. a clogged drain. Remove rear panel and clear drain of ice and possible obstruction.
Feb 08, 2010 | Maytag Refrigerators
Water is leaking from the freezer side of the my side by side.
The drain is clogged up. Remove all the ice from the bottom of the freezer. Then locate the drain hole at the back of the freezer. Using a turkey baser force hot water down the drain until it is clear. Then mix baking soda with water and pour it down the drain. Hope this helps!!
Also you can try this page http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE side by side Refr. water leaks under freezer side. seems to be connected to defrost cycle. water can be mopped up with paper towel. put small pan under fridge but does not capture water. Does not leak...
The drain is clogged in the freezer. Take off the back wall inside of the freezer, there is a drain in the bottom, use a turkey baster and hot water to clear all of the ice, pour hot water into the drain, put a piece of weed trimmer line down the hole and try and push the obstruction through, do not use a coat hanger or wire, you will puncture the drain tube and make bigger problems. Finish by pouring more hot water in and making sure it all goes down.
Jun 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Dec 31, 2008 | Refrigerators
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Water "pouring" from freezer condenser
sounds like drain in freezer is clogged and has iced over
so when unit goes into defrost water leaks into freezer bottom and freezes
you can either shut off fridge for a day and let ice in drain melt
and hopefully clear line
or u can take back cover off freezer section pour hot water in drain pan and make sure drain hole is cleared and draining down to pan
Jun 21, 2008 | Sub-Zero 611 / O Bottom Freezer...
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
1,195 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
