Question about ASUS M2V-MX Motherboard
On board video card
When I try to install the drivers windows gives me an error code 28. So when I try to play games I get an error saying my video card is not installed and will not support directx9.
    Genius:
  • 2,985 Answers
Where are you getting the drivers from? If it is from the Boards utilities disk go to the ASUS web site for drivers to see if you have the most recent driver available. Failing that the Asus support team will led you through the set up procedure.
Posted on Jun 17, 2007
SOURCE:
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Well i've installed the game and after "installing"....a small window pops up saying drivers not up-to-date,but my laptop is a hp dv6 no older than four months with 1GB graphics card (ATI radeon hd...
after installing the game, when and if you get that kind of error, it does not mean your pc drivers are not up to date, it means the game drivers are not up to date, meaning that the pc has noticed that the game could have newer patches to download. Try finding a patch for the game and see if that helps.
Sep 27, 2010 | Ubi Soft Peter Jackson's King Kong for...
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
Code 28
In most cases this problem code 28 occurs when Windows 2000 is upgraded to Windows XP and the sound card driver becomes deleted. To resolve this problem on your Windows XP. Right click "My computer" and select the "Manage" tab. This will open a window. In the left pane of the Windows click on "Device Manager". On the right side of the Window you will see a list of generic devices installed on your computer.In the list double click on "Sound Video and Game controllers". Once you see your sound card you right click it and on the opened window click on the Update tab. In most cases the code 28 problem is resolved that way but if rarely the problem still continues try downloading and reinstalling the sound card driver.
Good Luck!
Aug 19, 2010 | Microsoft Windows XP Professional
My computer says code 28 I do not have any driver installed for multimedia audio controller i have no sound and my cd rom does not get reconized
For Code errors refer to microsoft site: http://support.microsoft.com/kb/125174
The drivers for this device are not installed (Code 28).
To reinstall the drivers for this device, click Reinstall Driver
Procedure
Step 1
Click on "Start."
Step 2
On the "Start" menu, click on "Control Panel."
Step 3
In the "Control Panel" folder, click on "Performance and Maintenance."
Step 4
Click on the "System" folder in the "Performance and Maintenance" folder.
Step 5
Click on the tab titled "Hardware."
Step 6
Click on the box that says "Device Manager."
Step 7
Click on "Sound, Video, and Game Controllers."
Step 8
Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear.
Step 9
Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
Hope this help
May 25, 2010 | Microsoft Windows XP Professional
Can't play games after windows 7 install
Have you installed the latest drivers for your video card ? Because in your description you are running with standard VGA drivers from operating sistem. Find your laptop model and visit the manufacturer support site and see if they have driver for Windows 7. If not try to use Windows update from Operating Sistem, from Start menu - Applications - Windows Update.
Apr 10, 2010 | Microsoft Computers & Internet
Display memory error
check for the system requirement of your then check your video card if capable for that games. check for the proper installation of your games or program.
Jun 12, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Two worlds wont install or play i get an error saying its insufficent graphic card properties or config/ drivers everything is fine but i dont know how to check configuration
The drivers for the video card have to match the windows version that yuo are running. Go wither to the manufactures website of the computer or the video card maker, if a no-name PC and look for the correct driver. See if  theier is a newer driver or if  you have the same one  as the one that they recomment.
If that be the case ten the video card is not fast enought to play the game . You can upgrade to a different card.  If you need more help give us the make , model of computer and/or mother board and/or video board as the case may apply.
Jan 17, 2009 | Computers & Internet
My laptop wont play sound
there are many reason why you are having this problem, as i can see that you have code 28
Solution : Reinstall Driver, try to find your accompanied CD that goes with your pc
This code means the device was not installed completely.
To resolve this issue, follow the recommended solution. If that does not work, try removing the device from Device Manager and using the Add New Hardware wizard to redetect it. or remove the device physically and re-install it, or else You may need to obtain updated drivers if the error still occurs.
what kind of sound card?
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Unable to play the PC game Crysis
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link.
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
Mike
Apr 13, 2008 | Computers & Internet
ASUS M2V-MX Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
