Question about GE Slim Spacemaker 7-5295 CD Shelf System
CD spins but does not play
The cd light blinks and the cd spins but it does not play. After a short period of time np flashes.
    New Friend:
  • 111 Answers
Bad optical picup.
please change it.first of all try to cleane it by usig head cleaning disk.
nuwan.
Posted on Jan 16, 2009
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
GE Spacemaker, Model 7-5295 the cd light blinks and the cd spins but it does not play. After a short period of time nd flashes.
ND means "No Disc". It's probably a newer CD - one that's been copied, perhaps? It's got a format newer than what the CD player on that unit will recognize. Try an older CD.
Oct 02, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
TV makes a spinning noise coming from the lower right side.
If there is a red light blinking that means that the projection light needs to be replaced.
Jul 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Not reading cds
if you cleaned the lazer eye and it still has audio dropouts then you need to replace the lazer module.
Mar 20, 2009 | Audio Players & Recorders
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
GE 7-5295 CD error
i have the same problem exept that also the eject button is not working or the stop buttton.
Sep 25, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
GE Slim Spacemaker 7-5295 CD Shelf System Logo
387 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
