Question about Rockford Fosgate Punch P4002 Car Audio Amplifier
Any suggestions to get this transistor?
Is there a cross for these 2 transistors? FQA 46N15 FQA 36P15 Fairchild semiconductor to NTE, ECG or equiv?
    Scholar:
  • 39 Answers
Um, hard to find eh ? Ok here are 2 links for those parts, in stock at mouser. FQA 46N15: http://www.mouser.com/search/ProductDetail.aspx?R=FQA46N15virtualkey51210000virtualkey512-FQA46N15 FQA 36P15: http://www.mouser.com/search/ProductDetail.aspx?R=FQA36P15virtualkey51210000virtualkey512-FQA36P15 I didn't see any cross refs for that one. The only thing i didn't check was searching for other 150V N-Channel QFET, and 150V P-Channel QFET's, if you find some you could compare the datasheets. If you don't have time to lose, order from mouser :) Cya ! cheebster.
Posted on Jun 18, 2007
SOURCE:
WHAT ARE THE EQUIVALENT OF BF423 TRANSISTOR
Any high voltage low power pnp transistor. with the specs:
You really can find more and a lot quicker with Google. dc0e5c00-5b26-4e27-8053-b04e4586c4e9.png
Jun 23, 2014 | Nte S921TS Equivalent NTE288 PNP high...
Is c1383 the equevalent of 2sd468
  • 2sc1383 can be substituted for 2sd468 provided you match the gain which is marked as Q,R or S on the 2SD part and B or C on the 2SC part.
Mar 07, 2014 | Nte D468 Equivalent NTE293 TRANSISTOR NPN...
BC179 equivalent Available transistor
I would use 2N3251 or 2N3251A. The hfe is 100 and since you don't mention the hfe rank of your BC179, you need to check if your circuit is hfe dependent and will 100 fit the design. http://www.futurlec.com/Transistors/2N3251A.shtml
Feb 12, 2014 | Nte BC179 Equivalent NTE234 PNP low noise...
Is there any ic/transistor which is equivalent to d718
Your device is actually 2SD718 and can have possible substitutes as follows: BD245C, 2SC2681, 2SC2706, 2SC2837
BD245C 2SC684 KT819GM
Jan 08, 2014 | Nte Electronics - Others
Do we have a transistor which is equivalent to d718
NTE36 is allegedly equivalent.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 08, 2014 | Nte D718 Equivalent NTE36 NPN high power...
Bread paddle wont turn
You need to replace the transistor nearest the motor relay. It is a small transistor numbered 9013. Other transistors with the same number turn on and off other features of the unit such as heating. I got my transistors from fairchild semiconductor. Open the lid, unscrew the screw that holds the black plastic rim of the control panel, and then youll be able to pop off the control panel cover and see the two circuit boards, the one you want is the one without the lcd screen and large relays. Order your new transistors and replace.
Sep 03, 2012 | Cuisinart CBK-200 Bread Maker
Need to replace Q403 Where can I get it?
go to partstore.com then type in generic part number printed on transistor .Or look for replacement part number at NTE semiconductor website and type part number under 'cross reference guide"
Jul 29, 2009 | Nakamichi Audio Players & Recorders
Wurlitzer 200a electric piano replacement transistors
do you have the numbers off the transistors? i can look up the data sheets and pick a suitable or improved replacement.
Jan 12, 2009 | Music
Rockford Fosgate Punch P4002 Car Audio Amplifier Logo
414 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
