Question about Olevia LT32HVM 32 in. LCD Television
Input ports are dead
The Component Y, Pb, Pr / Y, Cb, Cr Input ports no longer show up as "Source" ports. When selecting the Source, these ports are not selectable and the video no long works to these ports. The DVI port shows that it is available by toggling up and down with the remote, so I may try to switch to using that input. Thanks for any suggestions.
Mine has done the same thing. Verizon Fios tech saaid he has seen this on several tv of that brand. Good luck finding service if you are in a smaller market, mine is over three hours away
Posted on Sep 18, 2007
Do you have the parental controls turned on?
Posted on Jun 18, 2007
SOURCE:
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
Samsung is only in black and white with av cables
It sounds like you connected a regular yellow composite video cable to the green luma (Y) port of a component video connection, this will give you just a black and white image because the red (Pr/Cr) and blue (Pb/Cb) ports and cables carry the color information.
Jan 30, 2012 | Samsung Televison & Video
What is Y.Pb/Cb.Pr/Cr can i us these as right and left speaker and a signal wire
Its for component video input. The cable has three connections, one red, one green and one blue. This is the highest quality connection for video you can get without HDMI. The audio will be run on a different cable
Sep 01, 2011 | Computers & Internet
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
How do I change the settings to 740 p or 1080?
Hello
1Connect the video outputs (Y, PB, PR) of the digital
set-top box to the COMPONENT IN VIDEO
jacks on the set.
Connect the audio output of the digital set-top box
to the COMPONENT IN AUDIO jacks on the set.
Turn on the digital set-top box. Select Component 1 input source with using the
INPUT button on the remote control.
- If connected to COMPONENT 2, select
Component 2 input source.
Feb 20, 2011 | LG 42LC2D 42 in. LCD HDTV
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Dec 09, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
I am connecting a Technika 1031 to a LG 19LS4D using a good quality scart. I get sound but no picture. Connecting via the Y, Pb/Cb and Pr/Cr ports does nothing. Am I doing something wrong?
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Mar 18, 2008 | Televison & Video
Olevia LT32HVM 32 in. LCD Television Logo
66 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
