Question about Samsung HCL4715W 47" Rear Projection Television
Convergence Board for hcl4715w Samsung TV
Hello Sir,
I am having trouble with my TV and after reading your postin assume it is the convergence board. I have not yet tried to manually adjust the convergence, but will.
I found the part exactly where you said. Can you please tell me where on the TV this part is located and guide me through changing it?
My e-mail is
I would really appreciate your help.
  • Anonymous Jan 19, 2009
    I have the convergence problem where did u locate the parts to fix your tv?
    Problem Solver:
  • 12 Answers
Part can be found at - the part is located on the floor of the tv, inside, the middle board. You will have to unplug the tv, carefully remove the back (and front speaker cover) of the tv, and unplug all of wires coming into it. You will also have to remove all of the screws holding it down. The replacement part will fit exactly into the same place - screw the screws back in, plug the wires back into the same place (if you've ever replaced memory in a computer, this will feel very familiar). Once everything is plugged back up, plug in the tv and restart, then run the smart convergence from the remote.
If your TV does not power up, and you have made VERY sure everything is plugged in correctly, then the board you've purchased may be faulty. Return it for a new one. The boards are fragile and can be bad straight out of the box (like computer memory *smile*).
Best wishes -
Posted on Feb 17, 2009
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
Convergence problem- ghost image. replaced
I have a similar problem with a 4715w and have a whole spare 4715w television to troubleshoot with .
In my case it seems that the board to the left is causing the problem ,
not detachable daughter board thet accepts the inputs or the center board with the flyback xfmr on it .
Jul 25, 2010 | Samsung HCL4715W 47" Rear Projection...
Convergence board for a HCL4715W? Which one?
It will be the one that has big black ICs STK394-020 for Parts callMats 1-800-628-1118 also there is 2 resistors 2.7 ohm near STKs replace if Bad.
Sep 25, 2009 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Anyone need any parts for the HCL4715W? Parting mine out.
More then likely set has 2 burt resistors on convergence board 2.7ohms
Jan 27, 2009 | Samsung HCL4715W 47" Rear Projection...
Replacing Convergence ICs
As long as you can solder you should be okay, however i would suggest getting your ICs at the following link because they provide free instalation instructions with pictures on how to remove and replace the Convergence ICs. heres the link.
Apr 26, 2008 | Samsung HCL4715W 47" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
Convergence board for Samsung HCL4715w
The Convergence ICs will need to be replaced , 95% of the time thats the problem they are on the sub board not the convergence board. You will need two STK392-040 ICs . you can get replacements at the following link and they will provide free installation instructions along with free on-line tech support when you install them. takes about 45 minutes. Heres the link.
Apr 19, 2008 | Samsung HCL4715W 47" Rear Projection...
TV won't power on
Disconnect the convergence board and see if the set comes on. If it does, and it probably will, replace the convergence board or the convergence amp IC's. Good Luck
Jul 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Red convergence problem
Yes I think the IC's on the convergence board are bad. This board is no longer available from Samsung but is available for repair or a swap from Find the telephone number and call them. or you could replace the two ic's on the board. Good Luck
Apr 08, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
158 people viewed this question
Jerry Greenberg
Jerry Greenberg
